Holes in runners....
Old 07-04-2005, 06:00 PM
Y2K SS's Avatar
Default Holes in runners....
Hey guys. I just installed my PRC's and was wondering about the holes in the intake runners that go into the rocker bolts. I hear thats how they are but do yuo patch them or anything??
thanks.
Old 07-04-2005, 06:21 PM
SPANKY LS1's Avatar
No. Put some tread sealant (blue locktite) on the rocker arm bolts, and put 'em in. Every ported LS head I've seen has those holes.
Shawn
Old 07-04-2005, 06:27 PM
Drew778's Avatar
Shawn
Nah use the red, it holds much better
Old 07-04-2005, 06:44 PM
Restricted User
CAT3's Avatar
Wayne, let Andrew dip your bolt in his red stuff and you wont get off! You can use locktite or RTV/Silicone, but I would discourage you from sealing the hole (opposed to just sealing the threads), as it can trap water/oil etc and work against the torque value and possibly cause issues later on.
Old 07-04-2005, 06:53 PM
SPANKY LS1's Avatar
Yeah, don't put it in the hole, put it on the threads right beofre you are threading it in. The red stuff will work, as long as you don't EVER plan on taking it apart again.
Shawn
Old 07-04-2005, 06:55 PM
jrp
SN95 Director
jrp's Avatar
ARP thread sealer is what i used.
Old 07-04-2005, 07:52 PM
Y2K SS's Avatar
thanks everyone. I appreciate the quick replies, lord knows I need it.
Old 07-04-2005, 08:24 PM
HavATampa's Avatar
I bought the ARP thread sealer to use for this too but was wondering should you still use loctite on the bolts with the sealer?
Old 07-04-2005, 08:42 PM
Restricted User
CAT3's Avatar
NO. Do not mix the sealer and locktite.
Old 07-04-2005, 09:19 PM
HavATampa's Avatar
So.....do you really need loctite at all on the exhaust rocker arm bolts? Seeing that the intake gets by ok without it.
Old 07-04-2005, 09:26 PM
Restricted User
CAT3's Avatar
Thread over locktite. And only on the intake is it necessary, since those are the bosses that are exposed after porting. Some ppl use locktite on all the bolts to prevent them walking out, I never had an issue with that on my car or others I wrenched.
Old 07-05-2005, 09:13 AM
BubaGumpShrimp's Avatar
if you really dont want to take them out use the green locktite, got some right here for you
