HOLY CRAP...help....metal piece in oil pan..PICS
Old 07-19-2005, 09:14 PM
Quickin's Avatar
Default HOLY CRAP...help....metal piece in oil pan..PICS..**UPDATE**
What in holy hell is this. Could a ring be that big?
The piece of metal is a little bit less thick than a penny. The pic with the watch in it shows it standing on edge. Its inbetween the watch and the nickle.
Each end of this piece of metal have been ripped from whatever it was attached to. It also has a slight curve to it like it wraps around something. Hopefully it doesn't wrap around a piston
http://img.photobucket.com/albums/v6...etalpiece1.bmp
http://img.photobucket.com/albums/v6...etalpiece2.bmp
Thanks.
Old 07-19-2005, 09:20 PM
strokedls1's Avatar
You can upload them onto tech with the manage attachments in the advanced posting menu. Browse for it on your computer and then click upload. If they are big you might need to scale them down first. Could it be needle bearings from a stock rocker?
Old 07-19-2005, 09:22 PM
Quickin's Avatar
I doubt I have stock rockers. I got the links up but not the pics.
I tried to load them using LS1tech management thing, what a joke. only 100 KB of space allowed. My pics have hardly anything to them at all.
Old 07-19-2005, 09:34 PM
co.6z28's Avatar
pics are up, looks like it could be piece on a ring, but im no expert
Old 07-19-2005, 09:36 PM
1QuickT-A's Avatar
I do not think that is a piece of a ring at all..
Old 07-19-2005, 09:48 PM
Quickin's Avatar
If it is.
The engine runs perfectly smooth, no smoke, nothing out of the ordinary. Sounds normal and very quiet.
If thats a piece of a ring wouldn't I be spitting something more out the pipes.
Old 07-19-2005, 10:20 PM
xssive's Avatar
Looks like the tip of the oil dipstick...
Old 07-19-2005, 11:06 PM
Quickin's Avatar
Maybe, but I checked the oil after I put in the new oil and it looked just fine. Had the twist in it still.
Old 07-19-2005, 11:20 PM
Brandon Boomhauer's Avatar
im guessing ring.
Old 07-19-2005, 11:34 PM
Quickin's Avatar
Originally Posted by Brandon
im guessing ring.
I didn't think rings are that wide. And wouldn't that big of a piece have me blowing smoke out the back?
Old 07-19-2005, 11:49 PM
just a pic courtesy of jegs.com
I would do a compression/leakdown test if I were you... But I am kinda intrigued to figure out how a top - compression ring got past the oil rings... unless its part of an oil ring...... hrmm
1QuickT-A's Avatar
I do not think its a piece of a ring.. it looks to wide like you said.. But, hard to tell from a picture. Also, it probably wouldnt smoke unless it was the bottom oil ring that broke and the bottom wring doesnt look like that..
Old 07-19-2005, 11:51 PM
strokedls1's Avatar
Looks like a ring piece to me.
Old 07-19-2005, 11:57 PM
Ferocity02's Avatar
Ring.
Old 07-20-2005, 12:08 AM
Quickin's Avatar
I guess I need to bring it to a speed shop and ask them in person.
If its ring piece I'm gonna drive it off a pier. Well.......
Old 07-20-2005, 12:17 AM
Quickin's Avatar
How does a ring piece break off like that? Detonation?
Old 07-20-2005, 12:21 AM
T/A-Speedfreak's Avatar
Maybe a piece of the bearing.
gator's 99TA's Avatar
its the bottom of a valve spring. you owe me a beer if i am right.
Old 07-20-2005, 12:29 AM
Quickin's Avatar
So should I not drive this damn thing?
I looked in the drained oil container and found nothing else in it.
Old 07-20-2005, 12:30 AM
Quickin's Avatar
I don't see how it could be a ring piece because its so straight. It seems that it would as big around as a basketball if it continued on around like a ring does.
