Choice between Heads, MTI 2E's or TEA 5.3L Stage 1.5
Old 08-09-2005, 07:38 PM
racer88's Avatar
Default Choice between Heads, MTI 2E's or TEA 5.3L Stage 1.5
Hey guys, I am going to be ordering some heads soon. I am wondering what my benefit will be with the MTI 2E's 5.7L heads vs TEA's 5.3L Stage 1.5. I know I can get the added compression just a bit which would be good for nitrous and my cam is a nice split duration for spray as well. If the $ wasn't the issue between the 2 companies which head porter would you use?
My motor is coming out for a complete rebuild forged. Nitrous will probably be used (dry shot) for alittle more umph but still need to remain with the ET cage rule of 11.50 because I won't cage this car.
I have a baby cam Comp 212/218 Xtreme lift (.554) I believe, not sure on the LSA that's turned some nice times with my stock heads and has trapped 116-117 in good air 45-55 degrees.
Anyone have any suggestions? I'd like to be able to run 11.7's this season on my skinnies and MT drags and run 11.4's with some juice.
Thanks!
Claire
Old 08-10-2005, 02:21 AM
JZ'sTA's Avatar
I would clearly go TEA.
Old 08-10-2005, 02:23 AM
Ben R's Avatar
Don't forget about ET Performance. They have some amazing CNC'd cylinder heads.
Old 08-10-2005, 02:38 AM
PREDATOR-Z's Avatar
TEA because they are notorious for added exhaust port volume which is a benefit on nitrous .
That is replying to your question.
However if you have the $$, AFR 205 is the one to go with.
Old 08-10-2005, 08:23 AM
BrentB@TEA's Avatar
Tea Not only do I feel we have the best 1.5 head available but with all 3 CNC machines up and running our lead time on 1.5 heads is only 1-1.5 weeks.
Old 08-10-2005, 10:35 AM
Ragtop 99's Avatar
If your goal is to limit the car to 11.5s, why not ditch the nitrous?
The heads (milled to achieve 11.0 CR) and a slightly bigger cam like a TR 220/220 112 or 224/224 114 will get you there and retain the drivability of your current cam.
Old 08-10-2005, 04:48 PM
racer88's Avatar
You have a PM
Old 08-10-2005, 04:51 PM
racer88's Avatar
It's up in the air with the spray right now, don't think a 28" tire is going to fit with my car being lowered a bit because I am not going to change my gears. Just alittle dry shot is all I want "Power on demand" type thing, with no worries because it will be all forged. I like my little cam it's awesome, you can't even hear that it's in there. We'll see I will see how this current cam does with heads, if not I can always change it later on.
I am happy if the car ET's 11.7's on motor and it's not on a slick, and if MPH is in the 118-119 range I will be more than happy, alittle juice on top of that even better.
Old 08-10-2005, 06:35 PM
WILWAXU's Avatar
I don't think you could go wrong with either company.
But (of course), I recommend the MTI Stage 2E's
Old 08-10-2005, 06:45 PM
conan's Avatar
I vote for MTI also. There heads are verry nice and customer service was outstanding. My first set of heads showed up looking like ace ventura delivered the box, the heads were a mess. Dave sent me a new set 1 week later no questions asked. I'll have some #'s in about a month when I finish the blower. Good luck.
Old 08-10-2005, 07:02 PM
racer88's Avatar
Thanks guys, I will give ya alittle scenario of this little cam. The car went 11.91 and 11.92 last winter with the stock wheels and Nitto drag radials. My Man was driving it though, so it shows this tiny cam has yielded some sweet power. The heads should pick it up a bit more, now that I have 2 sets of track wheels and one set with MT drag radials a 1.6 short will do what I am looking to do.
I still have alot of things to get down to the cam bearings, ARP bolts, etc. etc. LS6 oil pump I already have the rods, Olivers and JE pistons. I may get antsy and decide on another cam..........who know's easier to do the whole motor at once.
But I do love a loping LS1 and I do like mine as it is very stealth like. It's an eye opener when you get on it.
What I'd really like to know is the benefit of going with a 5.3L head vs the 5.7's........clearance shouldn't be an issue with lift seeing the cam is .554 and the pistons are dished.
Old 08-10-2005, 07:05 PM
racer88's Avatar
Originally Posted by conan
I vote for MTI also. There heads are verry nice and customer service was outstanding. My first set of showed up looking like ace ventura delivered the box, the heads were a mess. Dave sent me a new set in 1 week later no questions asked. I'll have some #'s in about a month when I finish the blower. Good luck.
Let me know how yours does. Good luck with yours too
Old 08-10-2005, 07:12 PM
conan's Avatar
Thanks, the 5.3l head has a smaller combustion chamber(cc) giving you a higher compression ratio, and you guessed it more power
Old 08-10-2005, 07:23 PM
racer88's Avatar
Hmmm, that sounds divine! Alittle monkey juice should do me just fine........and I can always up the shot OR, go bigger with the cam and launch the crap out of it to get my shorts into the 1.6's which should be pretty easy considering I pull off 1.78's and 1.74's pretty easy on Nittos.
Thanks! I am getting all excited over here.
Old 08-10-2005, 07:53 PM
TT_Vert's Avatar
i went 11.8@118.5 w/ TEA 1.5s, a very mild cheatr cam, 1.7x 60' and this is through stock exhaust system (its a c5 though) I dont see you having any problem hitting 11.5s and 118+ w/ a 5.3L TEA heads and that cam..
Dave
Old 08-10-2005, 09:15 PM
racer88's Avatar
You mean the current cam I have now?
Old 08-10-2005, 09:19 PM
TT_Vert's Avatar
IMO, if you get your 60's into the 1.65s you'll go 11.99ish right now. Add some heads, i bet you go 11.6x-11.7x with ease.
Dave
Old 08-10-2005, 09:36 PM
racer88's Avatar
Dave
I recently picked up some Convo Pro's already on the MT drag radials to try. If they stink for my M6 then I will go with an ET street. Our home track nowadays has been very inconsistent but great on the slicks only nights that I don't race at because I don't have slicks and DOT drag radials don't count.
It could change though into Dec when the air is alot drier here and the dew point goes way down into the 40% area compared to the 70% we have now with more humidity.
So........leaves me racing at Test and tune nights. If I can go out and even get the MT drags into the low 1.7's persay 1.72-1.73-1.70 then I know I will get them into the 1.6's at a track we've rented in Dec and that place hooks hard........cut a 1.74 there on 17" Nitto's with my 10 bolt On a good night at the home track 1.78's consistent out of my car is good on my 15" Nitto's on my 15x8 Welds. (Yes, she's<--me in deep love to race and I now have 3 sets of wheels for my car, 2 for the track and 1 for the street-whoot)
Thanks for the well wishes, I really think I've got some nice 1.6's coming out of the car and how I launch it with the MT's. My B/F thinks I should go ET street he doesn't think the MT drag radials are that good with M6's........but the Auto guys and powerglides are cutting 1.3's with them.
We will see, but thanks for the info
Old 08-10-2005, 09:44 PM
TT_Vert's Avatar
the M/T drag radial is an ET street. Or are you referring to the new drag radial they have? I run an 18" BFG drag radial and cut 1.7x 60's lauching at 2500 ish w/ a c5 that is 2" off the ground (NO weight transfer). So i dont see you havinga problem getting a good hooking M/T DR to hook and cut 1.60s if you put forth a little effort
dave
Old 08-10-2005, 09:53 PM
racer88's Avatar
I am talking about the MT DOT drag radial the new ones not the ET street.
I do know that on a well hooking track on the Nitto's I need to go out around 4K to get a decent 60' at the other track or a bog. At my home track I can go out around 38-3900 and I hook and bog over 4K I blow my tires off but with all that noise I still cut a 2.0
So I would think that a launch on the MT's around 5-5500 will do what I want and where I'd like to be. That's why trying them out on my home track first will tell me what they are most likely to yield at the other track before I go so I know if I have to add the ET street..........damn that will be a 3rd set of track tires since last week just bought some new 17" last week........still need to buy new 15" Nittos for my Welds for winter time sheeesh.
Dave, I will keep ya posted on the times, ET to the 60' after Dec 17th that's the date of the rental. Nice cool air into sundown and an excellent track...........heck ya, I am ready! Still have alot to do the motor is still gotta come out for it's rebuild.
Quick Reply: Choice between Heads, MTI 2E's or TEA 5.3L Stage 1.5
