Stock LS1 bottom end- What is it good too?
Old 09-20-2005, 03:17 PM
bcrishon's Avatar
Default Stock LS1 bottom end- What is it good too?
I was reading in a magazine that the stock lower end is good to 1000 horsepower. Has anyone heard that or tested it?
Old 09-20-2005, 03:46 PM
Kurtomac's Avatar
1000 hp yes.....and im hung like ron jeremy
550rwhp seems to be the borderline go or blow point
Old 09-20-2005, 03:57 PM
Z'mnypit's Avatar
What magazine did you read that in? I wouldnt want to be the one trying it.
Old 09-20-2005, 04:50 PM
DONAIMIAN's Avatar
Ive never heard of an LS1 failure due to power. RPM and detonation is what kills them.
Old 09-20-2005, 05:02 PM
chpmnsws6's Avatar
i've seen 783hp oout of a turbo car on the stock block
Old 09-20-2005, 07:34 PM
Somebody09's Avatar
What? The pistons and rods too??
-somebody
Old 09-20-2005, 07:56 PM
BlueSix's Avatar
The stock crank will take that much hp, but i think that's about the only stock parts (sans block) that will.
Old 09-20-2005, 07:59 PM
Order 66's Avatar
If you replace the bearings and use rod bolts i dont see why not.
Old 09-20-2005, 11:31 PM
GTObsessor's Avatar
^^^ what he said. There's a Camaro in Vegas pushing 625 to the wheels on a rear-mount turbo set-up *stock engine* (LOTS of cooling mods like Intercooler and Meth kit)... it's on a very conservative tune right now and they're still working it up to it's potential... they know the second that thing detonates, it's toast.
Old 09-21-2005, 12:00 AM
chpmnsws6's Avatar
i meant a bone stock motor with a HUGE single, sorry
Old 09-21-2005, 12:19 AM
99BackNBlackZ28's Avatar
The highest RWHP number I've seen out of a stock motor before it popped was 618 w/a twin turbo setup.
Old 09-21-2005, 01:19 AM
LSWannabe's Avatar
The stock crank is good to 1000hp all day.
Old 09-21-2005, 02:00 AM
mikemodano9c's Avatar
wasn't raymer making 700-800rw on that qmp single turbo setup formula...it was a stock motor with over 100k miles if i remember right...
Old 09-21-2005, 02:16 AM
WOT
WOT's Avatar
my horse numbers were kept low with a rich tune, but the torque numbers are decent.
Old 09-21-2005, 02:43 PM
chpmnsws6's Avatar
that was him!!!!!!!! he actually never blew it up either. he just decided to put good internals in before it all let go and it had a TON of dyno pulls on it
Old 09-21-2005, 02:56 PM
TrakDay's Avatar
I am making 550rwhp on my stock bottom end. Procharged cam and I don't get any knock! I want more too, but worry how much more the car can take revving to 7k rpms at the track and 8.5psi of boost!
Old 09-21-2005, 03:48 PM
DONAIMIAN's Avatar
so long as you keep an eye on your fueling and timing you should be ok, but If I had a FI setup I wouldnt bother with high RPM because all you have to do is up the boost to gain power, in contrast to an N/A set up where the bigger you go the higher you have to rev.
