Cam questions
Old 10-07-2005, 01:11 PM
supersix's Avatar
Default Cam questions
Ok guys I am changing my cam very soon. I have 3 cams in mind. Is there a way to determine if a cam will fit in my car with stock heads before I order the cam? the specs on the cams are:
Cam 1 - 240 244 .609 .612 110
Cam 2 - 242 248 .610 .624 110
Old 10-07-2005, 01:29 PM
NviouSS's Avatar
i would guess that you would need to mill or deck the heads for #3.
Old 10-07-2005, 01:54 PM
disposer's Avatar
i think that you will need to fly cut the pistons if you are going to use the stock ones but if you are going with an aftermarket ones with -2cc valve relife on them i think that you wont have a problem
Old 10-07-2005, 03:19 PM
supersix's Avatar
ok but is there a way to tell without guessing. can you not say a cam with x duration will cause the piston and valve clearence to be y?
Old 10-07-2005, 03:23 PM
smask04C5's Avatar
Yep, there is a way, degree it and clay it. That way you'll know for sure.
Old 10-07-2005, 03:27 PM
supersix's Avatar
I meant on paper to prevent me from claying it. Is there a formula?
Old 10-07-2005, 03:36 PM
smask04C5's Avatar
there probably is a formula for it, but if claying determines insufficient clearance, just flycut your pistons, not too difficult
Old 10-07-2005, 03:39 PM
cyphur's Avatar
only sure fire to way tell if they will fit is to clay it afaik.
Old 10-07-2005, 03:44 PM
supersix's Avatar
No but it becomes more expensive and I will have to wait longer to install it.
