What springs on afr's?
Old 10-24-2005, 04:23 PM
8 second mod
Noyzee's Avatar
Thumbs up What springs on afr's?
im pulling my afr's off for the winter, i will be doing new valve springs, freshen the heads, have evrything cleaned ect ect
what spring kit should i look into for about a 600 lift cam?
thanks
Old 10-24-2005, 06:34 PM
30th t/a's Avatar
patriot golds or the 921's. i had the golds with my g5x3. they worked perfect and their a good price too.
Old 10-25-2005, 08:38 AM
8 second mod
Noyzee's Avatar
I thought the afr's accepted different springs? didnt know the 921's would fit?
Old 10-25-2005, 09:06 AM
PREDATOR-Z's Avatar
All drop in springs will fit. (any that doesn't require seat machining.)
Old 10-25-2005, 09:11 AM
SideStep's Avatar
It is my knowledge that the base AFR springs are the same as the "Patriot Golds" "PRC Duals" just without the nice gold finish. I am using them with my current cam (see sig.) shimmed to 1.740 install height.... Been working fine... 22 dyno pulls to 7200+
POST#9
https://ls1tech.com/forums/showthrea...highlight=gold
POST#19
Any other opinions???
Old 10-25-2005, 10:27 AM
LS1 Tech Administrator
Patrick G's Avatar
That is correct. The springs that come standard on the AFR 205s are pretty impressive. FWIW, Comp 921 springs drop right in and you can even use the Ti retainers that come with the factory duals on the 205s (they actually fit better than the retainers that come with the 921s).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 10-25-2005, 05:37 PM
destroyerSS's Avatar
I put manley nextek duals on my AFR's and cam is in sig
Old 10-25-2005, 09:55 PM
RPO_Z06's Avatar
The spring base is larger on the AFR's but the 921's fit in the base that comes on the AFR's, if you buy a 921 kit you can use everthing but the base that comes with the kit,
AFR's have a larger i.d. than stock, the thickness is the same both ways on the base, its .040 so setting pressures up is easy.
Old 10-26-2005, 08:02 AM
8 second mod
Noyzee's Avatar
looks like i will probably go to 921's
Old 10-26-2005, 09:29 AM
SUTTERERMAN85's Avatar
921's are what i would roll with for that
Old 10-26-2005, 11:05 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
Do NOT use the 921's with aftermarket heavy rocker gear....they work well with stock rockers but are not as effective with aftermarket pieces. Go with our 8019 spring upgrade which has slightly more seat pressure than the 921's and a higher spring rate for better "over the nose" valve control. They are the spring of choice for any aftermarket rocker set-up.
Just to re-iterate, the 921's have been flawless with the lighter weight stock rocker arms, not to mention have a track record second to none, but I don't recommend their use with anything else.
Hope this helps....
Tony
PS....Our 8019 springs are custom made for us with the same proven material our standard spings are made with, but have more seat and open pressure to better cope with higher lifts and more aggressive camshafts and RPM.
Old 10-26-2005, 11:43 AM
vettenuts's Avatar
Hope this helps....
Tony
Is it correct to assume that a lifter change would also be required with the 8019's and non-stock rockers (for instance Crane 1.8's)?
Old 10-26-2005, 12:12 PM
eb02z06's Avatar
Tony what are the specs of the 8019 springs and can the stock lifters handle them?
Old 10-26-2005, 01:04 PM
Flow Wizard
Default More 8019 Spring info...
Personally, I think a stock lifter is a decent "gamble" for lack of a better word assuming a tight budget etc., but lets face it, an aftermarket higher quality lifter wouldn't be a bad move. Keep in mind guys that this spring is for more aggressive applications and if your looking to make big power and retain a reasonable amount of reliability that usually entails spending money for the better parts.....no news flash there.
Our 8019 spring is not for the faint of heart....it sets up at 1.810" with 155 lbs. on the seat, has a rate of 428 lbs/inch which will yield an open pressure of 412 lbs. @ .600 lift. We rate this spring to .650 lift BTW and is a much better choice for a guy running right at, or slightly under .600 if he plans on turning the wick up on his combination.
Tony M.
PS....BTW, AFR's upgrade price on this spring is around $100. Far more cost effective than the 921's....(and you guys say we always charge too much! )
Old 10-26-2005, 01:27 PM
eb02z06's Avatar
Tony I have no problems running a better lifter, for example the comp R's. My problem is how to properly set them up? From all my searching it seems awhile back that everyone was having issues with low dynoing #'s due to these lifters not being set up properly? Can they be used with the factory rockers or does an upgrade to the rocker become necessary here too? And lastly how do you set them up?
Old 10-26-2005, 02:38 PM
Flow Wizard
There are other lifters available that aren't as fussy in the preload department, have different internals, and (of course) are twice as much money. PM or call me at AFR and I will get you up to speed on your options and set-up of the "R"s.
Tony M.
Old 10-26-2005, 03:01 PM
8 second mod
Noyzee's Avatar
tell me what i could use to go to a solid roller? big momba cam?
cuz i may go this route ls2 block.
im undecided right now. hell i may go with the world block. who knows.
Old 10-26-2005, 03:47 PM
vettenuts's Avatar
Tony,
I see some guys having good success with your standard springs, smaller cams and 1.8 rockers. Do you have the installed height, seat pressure and spring rate that you use for these? My interest is in idle to 6,200 and no higher so I don't want to use more spring pressure than necessary.
Old 10-26-2005, 04:29 PM
Flow Wizard
Originally Posted by vettenuts
Tony,
Standard springs are fine in most mild and moderate applications....It's only the high lift stuff and with the higher duration #'s (and tendency to want to scream and make power at high R's) that require a stiffer spring. Our standard springs have been extremely effective and reliable and are a better choice if the application calls for them....there is no upside to having more spring than you need.
They have 135 lbs on the seat and around 350 lbs. open at .580 lift.
Tony M.
Old 11-05-2005, 08:07 PM
Viper's Avatar
Tony,
I have Enduratech springs on my AFR's with these specs now:
OD ID VC Load VO Load Lift Coil Bind
1.255 0.827 138# @ 1.750 371# @ 1.150 0.6 1.09
I'm thinking of going to the 8019. I have Morel lifters. Any issues with the two?
Cam is a 227/231 571/575 custom Ed Curtis cam. Put out 432hp 405tq.
We saw a little valve float after 6600rpm which is why I was considering these springs.
