GTO Cam Specs/Suggestions??
Old 10-28-2005, 11:44 PM
GoatBoy14's Avatar
Default GTO Cam Specs/Suggestions??
Does anyone know what the stock cam specs are for the 2004 GTO A4?
Also, I was wondering if you could give me some ideas as far as a doing a cam swap,somthing thats not too radical.
I am gonna do the swap this spring. I am looking at a Vig 3200, Shif Kit and Servos, Springs and Rockers, and Long tubes. Any setups tips would be cool. Thanks
Alex
2004 GTO A4
TunerCAT
Old 10-29-2005, 01:51 AM
CaptUSA's Avatar
I'm going to tell you the same thing 90% of the others are going to tell you. "Not too radical" but good power is the TR224 on a 114 LSA. It's bad ***. I don't know of any headers for the Goat, but I'm sure they're out there. GL on your build.
Old 10-29-2005, 02:26 AM
FIVE-O's Avatar
I know its on here somewhere.
Regardless...Its just too damn small..........sumpin like 197/.479 or therabouts
Old 10-29-2005, 04:49 PM
Rob
Rob's Avatar
Stock '04 GTO cam is a '01-'02 F-Body cam. I had mine on a cam doctor and that's what it was.
Old 10-29-2005, 09:39 PM
Z06er's Avatar
SS works builds GTO headers.
Old 10-30-2005, 05:04 AM
GoatBoy14's Avatar
Rob, do you know the numbers on that stock 01-02 F-Body Cam?
Old 10-30-2005, 06:17 AM
baldurann's Avatar
Stock 01+ LS1 cam is rediculously small. The stats are in JRP's SuperFAQ, if you really want to know what the numbers are. Like others have said, the TR224 is a tested and proven camshaft that delivers good numbers, and great street manners.
Old 10-30-2005, 09:40 AM
PREDATOR-Z's Avatar
Take a look at some Australian grinds. They are the pros when it comes to that body platform.
Basicaly a good trqr, tight lsa cam
Old 10-30-2005, 02:55 PM
TheZaZ's Avatar
I have an 04 GTO....getting ready to do a cam swap next weekend as long as all my parts arrive in time.
As for the stock specs of the goats cam.
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
Like stated above, the is rediculously small.
Old 10-31-2005, 06:34 PM
ShevrolayZ28's Avatar
Duration@.050 196.37 intake 208.72 exhaust
Lift .464 intake .479 exhausts
LSA 115.92
Old 10-31-2005, 07:36 PM
GoatBoy14's Avatar
Thanks for the info guys. Much appreciated!
GoatBoy
Old 10-31-2005, 10:13 PM
PREDATOR-Z's Avatar
They are the same cam
