Which cyl bank is typically the leanest?
Old 11-08-2005, 06:19 PM
mr2guru's Avatar
Default Which cyl bank is typically the leanest?
Just trying to place my wideband on the leanest bank.
Thanks
Old 11-08-2005, 06:36 PM
blkZ28spt's Avatar
Lean tends to be the passenger side. Also the further back you go the leaner it gets. The leanest cylinder typically is therefore #7.
Old 11-08-2005, 06:37 PM
treyZ28's Avatar
anyone know why?
Old 11-08-2005, 06:43 PM
Wnts2Go10O's Avatar
Originally Posted by treyZ28
anyone know why?
look at how the intake sytem is setup. all that air is getting crammed into the back of the motor and which one will receive the most?...#7. this would lead me to assume that a setup wehre u could tune each cylinder individually on FI would let you keep your stock bottom from blowing up aorund 550rwhp. because essentially its a lean condition really.. if im wrong guys, correct me.
Old 11-08-2005, 11:25 PM
ArcticZ28's Avatar
Umm... pretty sure the #7 isn't on the passenger side
Old 11-09-2005, 02:15 AM
mr2guru's Avatar
Going by the theory of intake air velocity and that the average flow of air is increased by how far back the runners are from the TB.
The drivers side should be the leanest as they start on the passenger side (set back) and go from there.
I think I will put it on the drivers side Bleh...sounds good at least.
Old 11-09-2005, 12:18 PM
blkZ28spt's Avatar
That's right, 1 is an odd number after all.
Old 11-10-2005, 04:25 AM
Phil'sC5vette's Avatar
The motors on here that have failed lucky number 7 is the winner
Old 11-10-2005, 09:05 PM
LeMansBlue04's Avatar
2 4 6 8 Passenger Side
Rear--->
1 3 5 7 Driver Side
Cylinder #1 is at the front of the engine on the driver side, all odd numbers
Cylinder #2 is at the front of the engine on the passanger side, all even
Its been this way since the first small block Chevy way back in the 50's.
