Ron Jeremy cam - what heads?
Old 11-09-2005, 09:38 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Default Ron Jeremy cam - what heads?
I deleted the last thread I posted cause it was confusing me as much as it was you.
Thinking about going with this cam instead. Read that it clears fine as well. What heads would work best with this cam w/out flycutting? Would the PRC's work? anyone have heads w/ this cam?
thanks.
Old 11-09-2005, 10:56 PM
LSUxBlake's Avatar
I'm pretty sure the PRC's would work, provided you use the stock sized valves (if those are even offered from PRC). If you get the 2.05's, chances are strong that it wont clear and you'll need to flycut.
Old 11-09-2005, 11:09 PM
Lithium's Avatar
Yeah I was talking to Bryan over at TSP. He said that he has the PRC's with 2.02 valves that will clear the MS3...so I am guessing it should clear the F15 as well.
Old 11-10-2005, 08:42 AM
Lithium's Avatar
bump...
Old 11-10-2005, 10:15 AM
Kraest's Avatar
I'm running stock heads w/ PRCs. No valve float up to 6900 rpm.
Mike
Old 11-10-2005, 11:35 AM
PortPros1's Avatar
thanks.
We can port a set of heads to match your cam and application. We build our heads one set at a time as ordered. All of our heads are flow tested, you get flow sheets and blueprint records. We use Ferrea valves, Comp Cam springs, retainer and locks. Our stage two 241 castings would work very well. Give me a call, PM, e-mial ask for Harold. www.PortPros.com PortPros@sbcglobal.net
Old 11-10-2005, 09:57 PM
distortion_69's Avatar
Could hold out for the trickflows and see how they do. Supposedly they have great p/v clearance.
Peace,
Josh
Old 11-11-2005, 11:10 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We have a p/v friendly version of the 5.3l stage 2.5 available that will work perfect for you Feel free to call me when you get some time & we can talk over your setup.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 11-11-2005, 05:51 PM
BAN-LS1's Avatar
AFR 205's. thats what futral reccomended to me
Old 11-12-2005, 09:10 AM
Phil'sC5vette's Avatar
I might be selling my AFR 205's milled .30
brand new in the box $2050 with MLS GM gasket
