LS6 head on LS1
Old 11-19-2005, 06:47 PM
Xtnct00WS6's Avatar
Default LS6 head on LS1
Are there any problems with putting LS6 heads on an ls1?
I read an article that says the exhaust port moved .125 for better flow. Will my Pacesetter headers still work fine and bolt up? How about my LS1 intake, will that NEED to be upraded to the LS6 to work?
Here's the article I'm referring to:
http://www.corvettefever.com/techarticles/18479/
Old 11-19-2005, 06:54 PM
Moderator
davered00ss's Avatar
A lot of people run ls6 heads on ls1's. Never heard of a problem.
Old 11-19-2005, 09:38 PM
dudas35's Avatar
The floor of the port was moved up to increase flow, the port itself was not moved.
Old 11-20-2005, 07:42 AM
Phil'sC5vette's Avatar
Your car will work fine
Old 11-20-2005, 08:09 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I thought that this was actually fairly a common choice.
Old 11-20-2005, 09:45 AM
99C5Coupe's Avatar
The article says you will have to use the LS6 intake and throttlebody with these heads.
Old 11-20-2005, 11:05 AM
Xtnct00WS6's Avatar
Yeah, that's the wierd part. I've heard of people doing it too and with no problem. I'm sure the LS6 intake would work much better than my LS1, but I dunno if it's actually NEEDED to work.
Old 11-20-2005, 02:26 PM
kenp's Avatar
The LS1 intake will work.
Old 11-20-2005, 05:47 PM
Firehawk441's Avatar
Just bolt them on
Old 11-20-2005, 09:40 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Most people that are doing heads will most likely end up with a FAST intake or an LS6 anyway.
