cometics question
Old 11-20-2005, 02:13 PM
pdd
pdd's Avatar
Default cometics question
i pulled my heads and cometics gaskets. the gaskets have a lot of the old gasket material on them. so i cleaned them the best i could but everytime i pick them up i see more crap on them. how clean do i need to get them? every time i pick them up i see more crap between the layers .seems the old gasket material is everywhere.
Old 11-20-2005, 04:27 PM
strokedls1's Avatar
Use some brake cleaner to get all that stuff off. You don't want something like to be the reason the heads don't seal.
Old 11-20-2005, 04:54 PM
SideStep's Avatar
FYI, I have used copper-spray sealant on my last three Cometic installs and have had no issues from leaks....
Get that thing together!!!
Old 11-21-2005, 02:17 AM
pdd
pdd's Avatar
so soak the cometics in brake cleaner?
Old 11-21-2005, 07:06 AM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
Are you trying to clean the old (used) head gaskets??
Old 11-21-2005, 08:26 AM
SideStep's Avatar
Yes he is, you can re-use Cometics...
Old 11-21-2005, 09:23 AM
BadAssFast's Avatar
We did the same...
Old 11-21-2005, 10:49 AM
strokedls1's Avatar
You don't need to dip it in brake cleaner. Just spray it off. I also use copper spray on mine before installation. It sounded like there was dirt or other stuff on the gaskets. It only takes one can of cleaner and 5 minutes of your time to clean and prep them. They can be reused a couple times from what cometic implies.
Old 11-21-2005, 12:46 PM
ROCNDAV's Avatar
Who makes the spray and where can it be bought? Is it a permatex blue can? Is it available at Autozone?
D
Old 11-21-2005, 01:40 PM
SideStep's Avatar
D
Yes, you can get it (Spray Copper Sealant) at Autozone... The can I got was copper in color...
Old 11-21-2005, 02:00 PM
pdd
pdd's Avatar
ok ill spray them with the brake cleaner then. theres no dirt on them just alot of the old gasket material from the original head gaskets. i got most of it off but i am always finding more here and there
Old 11-21-2005, 02:50 PM
Viper's Avatar
Are you saying the original heads were not cleaned thouroughly before the cometics were put on??
Old 11-21-2005, 03:57 PM
ROCNDAV's Avatar
I keep cleaning both my heads and deck but when I removed the heads after claying the piston, I noticed an oil residue on both sides of the cometics. I dont know where it is coming from. Does this affect the sealing properties and is aybody else seeing this?
Old 11-21-2005, 07:04 PM
Phil'sC5vette's Avatar
Ive been hearing more and more about guys having problem with those gaskets
Old 11-21-2005, 07:09 PM
pdd
pdd's Avatar
the heads were cleaned but i didnt get 100 percent of the stuff off the block. i had no leaking problems though
Old 11-21-2005, 08:16 PM
BadAssFast's Avatar
?? Like what...i've knows a LOT of folks who use them? I use them. Make sure they are oriented corectly, torqued correctly etc. They do an especially good job at matching iron to aluminum.
Old 11-21-2005, 09:11 PM
SideStep's Avatar
No issues here... I have installed 4 sets...
Old 11-21-2005, 10:58 PM
Restricted User
CAT3's Avatar
I guess I need to put copper spray on my "to get" list.. My ETP heads should be here in about 7days or so ARP Studs just arrived, yes!
Old 11-22-2005, 03:55 AM
pdd
pdd's Avatar
the hell with it- i bought a new set of cometics just to be sure i dont have any problems. i did reuse these old ones a couple times though with no problems what so ever
Old 11-22-2005, 06:29 AM
gwj
gwj's Avatar
What I was trying to figure out, where did all the crud come from. Wasn't sure what was being cleaned.
