Patriot 226/226 112 cam
Old 11-30-2005, 06:27 PM
redmist's Avatar
Default Patriot 226/226 112 cam
Anybody see any dyno result for this cam? The price is hard to beat at $279.
Old 11-30-2005, 07:55 PM
1CAMWNDR's Avatar
Not seen any results, but it looks like a good torque and power cam to me!
Old 11-30-2005, 08:27 PM
d james's Avatar
whats the lift on that cam, and are the cams hard on the springs? looking for a cam that doesn't need new springs every 25 thousand miles. Your right thats a price that can't be beat
Old 11-30-2005, 08:34 PM
redmist's Avatar
Default cam lift
Advertised .585 lift.. little harder on the springs than the TR224 which is .563 but not by much. I think the comp cams beehive springs would be a good match, they are good to .600 lift.
Old 11-30-2005, 08:40 PM
khris99s's Avatar
Had this cam in my 98 A4 and loved it. Pulls hard.
Old 11-30-2005, 08:46 PM
1998sscamaro's Avatar
were did u find this cam, been looking for a good cam. is it a "radical" cam?
Old 11-30-2005, 09:19 PM
redmist's Avatar
Nope not radical at all. Good street cam. Rough idle but from what I understand no PCM programming required. If you do want to program a little you should lean out the idle and add a little idle only advance an richen up the upper end.
Old 11-30-2005, 09:25 PM
Greed4Speed's Avatar
I have a similar cam (GTP420 226/226 .590/.590 112). Haven't installed yet, but been wondering about it also. I'll probably step up to Patriot Gold springs since you can get a complete spring kit w/Ti retainers, seats, etc for ~$250.
Where is redline on these cams?
Old 11-30-2005, 10:26 PM
where did you find the cam at? and do they have a little bit more of an intense cam for the same price?
Old 11-30-2005, 10:52 PM
JBIRD02's Avatar
Patriot Performance -------------------------->
theyre a sponsor
Old 11-30-2005, 11:05 PM
HILL_SS's Avatar
How long will springs last with the .585 lift. I was looking into there LS6 Stage II Heads and this cam. There heads come assembled with Dual Gold Springs that are good to .650 lift. Do yall think these will hold strong for a while? Im looking for something that can be drove everyday without alot of maintence and still make good power...
Old 12-01-2005, 07:16 AM
redmist's Avatar
As long as you don't live in the 6500 to 7000 rpm range they should be fine. I did a lot of research into the Comp Cam behive springs. They work really well with lighter seat pressure and I haven't heard of any failures yet. They are around $157 on ebay. FYI
Old 12-01-2005, 07:24 AM
LS1 BU's Avatar
Looks like a comp XER
Old 12-01-2005, 07:45 AM
PREDATOR-Z's Avatar
Please, to all who think that they can put a cam in their motor and not touch the springs for over 25K miles do this:
Either get a cam with less than .550 lifts
Or
Do not touch the cam you allready have.
Old 12-01-2005, 08:42 AM
redmist's Avatar
Why does lift greater than .550 create eventual spring failure?
Thanks.
Old 12-01-2005, 09:01 PM
Because the springs get worked harder. It takes a more agressive lobe to create higher lifts which fatigues the springs quicker.
Kind of like running shoes. Run on them at 300 lbs and run on them at 180lbs and see which lasts longer.
