cam with stock stall
Originally Posted by formula8r
is there a cam for the A4 that is streetable and does not require a higher than stock stall? if so which specs will work?
With that cam & stock TC, part-throttle response was very crisp & snappy. Great for around town driving. Could easily break the tires loose with a slight part-throttle jab on the gas pedal. BTW, the cam is the CompCams 206/212 .515/.522 112 installed 2 degrees retarded to take away the 2 degrees advance ground into the cam.
I have added a 3500 TC to help me reach my goal of an 11 second timeslip. And that little cam w/1.85 rockers got me there! Now I'm going to see what adding headers to the setup will do to improve my ET.
This type of cam can ENHANCE the performance of a stock TC setup. After our track closes down, I'm seriously considering reinstalling my stock TC. That is not to say the driveability of the TCI3500SSF is poor. (In fact it is very good for a stall that size) I'm saying the the driveability of the stock TC with the cam is that much better in the sense of snappy throttle response.
Now knowing what I know, and if I were to do it all over again, I would pick a cam with ~210 intake duration and lift of ~.560 to avoid the expense of having to use the 1.85 rockers. However, I beleive there are some benefits of using a larger base circle cam with higher ratio rocker arms vs. small base circle cam with high lift ground in. But that is a whole nuther topic.
Anyway, hope my experience helps your decision.
I would think that Thunder's CheatR cam 214/230 .601/.578 117 LSA would be ok on a stock converter. They say it works good with stock manifolds/cats. Off idle-6800 rpms. Or their "Old Man Truck" Camshaft - 214/220 .600/.525 115+2 LSA .
I have a 218/224 562/568 on a 114 in my 2000 vette with a stock stall. It has a very slight chop at idle in park, but smooths out as soon as you drop it drive. It idles right at 675. Picked up 23 to the rear wheels over the stock cam. I'm very happy with this choice. It is a custom grind from comp.
Originally Posted by PREDATOR-Z
I working on one myself at the moment:
210/224, .556/.568 115+1 lsa
I also like what Katech Stage I cam has to offer. Here's a link to their old thread:
https://ls1tech.com/forums/generation-iii-internal-engine/413097-katech-camshaft-information.html
IIRC, that is basically and LS6 cam with the lsa tightened up. That's the kind of improvement street cars need.
The main reason Im lookin in on a cam is I know my timing chain has had it with 119k on the clock and since Im gonna be right there.....
gomer and I will be R&Din a "stock converter gomer grind" very soon
