octane rating
octane rating
Not sure if this is where to post or not. I was just wondering what octane rating you guys run. Or i guess how high of octane is safe to run in our cars. I always run at least 93 but and thinking of gettin some 104 or 110 for track days. Wanted to check with you guys to see if it was safe and what you guys all run. Thanks
6 Second Club Moderator
Location: Your girl's back door giving her the long stroke while you're at work
If the race gas is leaded it will probably mess up your O2 sensors. It happened to me when I used 110 but after a couple tanks of 93 they were good to go.
I run 91. Using a higher octane then what is needed will not benefit you. Like FASTLS1 said run the lowest possible. When your motor is running close to detonation it will run most efficiently because most of the fuel is being burned at right point, and using a higher octane will not allow this to happen because your motor is not running hot enough to burn the higher octane gas where it is needed to burn.
Use only the fuel that your motor is tuned for. The only way your going to get added power from higher octane gas is to have a diffrent tune for the higher octane gas. Otherwise you motor makes peak HP on the brink of detonation. Which means, only run the fuel that you need.
Originally Posted by Steve Burger
I will be running VP 110 but I will have 13:1 compression.
