tr 224/224 112lsa ??
Old 01-16-2006, 07:22 PM
99ccz28's Avatar
Default tr 224/224 112lsa ??
Would a tr 224/224 112lsa cam be ok in my automatic with the right stall and good tuning or should i get a 114lsa ? Thanks
Old 01-16-2006, 07:34 PM
DevonsZ's Avatar
That cam should be fine with a stall & tune. I would get at least a 3200+ rpm stall tho.
Phil'sC5vette's Avatar
use the search button.
Old 01-16-2006, 07:38 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
It has been questionable lately.
But yeah, If you plan on spraying it in the future...that would be the only reason i would get a 114 on that cam. 112 should work fine.
Old 01-16-2006, 07:57 PM
LS1Queen's Avatar
we had that cam with a 3600 converter it felt as good as the stock cam after a tune made 380/385 with unported 5.3 heads and a 3.73 12bolt
Old 01-16-2006, 09:42 PM
Hennytime's Avatar
why would that make a difference? i understand that cams shouldnt be spray specific unless you spray over 200, and the 112lsa should only really lower the peak hp a few hundred rpm,i dont understand why it the lsa makes a difference in theis scenario
Old 01-16-2006, 11:34 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
And it doesnt really make a difference. I was just prodding to see where he was going with his setup.
Old 01-16-2006, 11:36 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Yeah with a shot less then a 150 is really doesnt make a difference.
Old 01-17-2006, 08:28 AM
99ccz28's Avatar
i do not plan on spraying. let me ask what cam would be best with an auto...
f13
tr224
tourquer 2
i dont rev my engine very high, right now only 5500 maybe a little more when i get a cam but that is y i was gonna go with 112lsa...they make more lower rpm power than a higher lsa is that correct. any suggestions or input would be great. thank you
Old 01-17-2006, 04:23 PM
99Freeze's Avatar
Default tr224
I have the TR224 on 112 with a SY3500. This is a really loose converter until you get use to it but after a while I didn't even notice it there. There car pulls really good from 3K to 6K. It's not the biggest cam out there but I didn't really want all that. Just something with a little street kick and easy on the springs. I am very happy with my setup. Oh yeah that's with 3.23 gears
Old 01-17-2006, 06:56 PM
SSilverSSurfer's Avatar
that would kick ***...but your gonna wanna go bigger after you see the potential
Old 01-17-2006, 06:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
