heads for f13 cam
Old 01-18-2006, 08:37 PM
brandon1221's Avatar
Default heads for f13 cam
Ok guys i searched and couldnt find any thread on what would be the best budget heads to go with an f13 cam. Ive been looking at patriot heads since they seem to be a good price. I dont know if i would want the ls6 or 5.3 style though, then if i got the ls6 would i want the 2.02"/1.57"/59cc. or the 2.055"/1.57"/64cc. The car is daily driven and will prob. get a 150 shot of n20 this summer.
Thanks,
Brandon
Old 01-18-2006, 09:04 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Brandon you may also look at the PRC LS6 cylinder heads we have on HUGE SPECIAL!! If you get some extra time give me a call, we have a new nitrous setup exhaust port that I can put into a LS6 head that would work really well The last set I finished went close 314cfm @ .600 with a 2.02 valve!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-18-2006, 09:19 PM
how long will those heads be on sale. It will be a while before i order heads, and im still debating on doing heads, nitrous, or a 12 bolt.
Old 01-19-2006, 09:12 AM
Gunnar@Patriot's Avatar
We can provide you the best pricing on some of the best heads on the market. We have our LS6 style heads which are always a great value. We also have our 243 CNC ported castings available at great prices. We can do you a set of our CNC ported castings assembled with Patriot Gold springs and 2.00"/1.55" valves with new GM MLS head gaskets, OEM head bolts, and shipping anywhere in the US for $1125.00 per set. This is a great deal ! These heads will come with a flow sheet specific to them. You will be well pleased with the flow and quality of these heads. Give us a call and we will be glad to answer any questions you may have.
Old 01-19-2006, 09:19 AM
oange ss's Avatar
would I need to flycut for the F13 or Torquer II with PRC Stg 2.5 heads ?
Old 01-24-2006, 07:17 PM
so if i was to get the ls6 heads why are would the 2.00/1.55 valves be better than the 2.02"/1.57"/59cc or the 2.055"/1.57"/64cc. Also I will be spraying a 150 shot on these.
Old 01-25-2006, 12:07 AM
SMonty's Avatar
I'm also considering an f13 cam, and the 243 castings from patriot. would that require fly-cutting? or should it go smoothly? and what numbers to expect with bolt-ons. thanks guys
Old 01-25-2006, 12:11 AM
SSU's Drunk Typing Whore
Lithium's Avatar
Nope.
Old 01-25-2006, 07:43 AM
slow trap's Avatar
the teas like the f13 cam also.
Old 01-25-2006, 08:18 AM
ALWAYS check PTV clearance. We have had many, many customers use the F13 with our heads without any PTV issues.
Old 01-25-2006, 08:36 AM
Z'mnypit's Avatar
I ran an F13, with Patriot stage II LS6 heads. Didnt have any PtoV clearence issues. That cam will clear a 2.02 valve perfectly, no flycutting required. The Patriot LS6's/F13 seem to be a stought little combo. I think its blk01ss or something like that, running 11.1xx's with this combo.
Brandon- Just FYI. I ran my setup with a 62cc head, 2.02 intake valve, 1.60 exhaust valve. This put the CR right around 10.7-1 with the stock thickness gasket. I had the TNT F1 kit spraying 100-150. So you'll be fine. Good luck!
Old 01-25-2006, 09:39 AM
The PRC Stage 2.5 LS6 heads are currently $1249.99 with 2.04/1.575 valves. We offer the PRC stage 2.5 LS6 heads with flow sheets that we 100% guarantee! The last set of 2.04 valve LS6 heads went 318cfm @ .600!!!!
__________________
Jason
2005 Twin Turbo C6
Old 01-25-2006, 12:56 PM
What did you dyno with those heads and that cam NA, then what did you dyno spraying a 150shot?
Old 01-25-2006, 01:22 PM
Z'mnypit's Avatar
Never made it to the dyno. I got everything installed, drove it around for awhile then I spun a rod bearing so I had to pull the motor. If I had to guess what it would have made, I would guess around 400 or so on the motor then little over 500 on the jug. Autos suck on the dyno. Its track times that count!
Old 01-25-2006, 01:56 PM
funnelone's Avatar
Default Jason TA
Are these the heads you are talking about for 1249?
xxx.texas-speed.com/shop/item.asp?itemid=134&catid=40
Quick Reply: heads for f13 cam
