Interesting post, ET heads dyno 410rwhp than 467rwhp
Readers digest version....
** Car dynos low 410rwhp on dynojet
** Doesnt know why
** Inspects and finds a broken valve spring
** Redynos on Mustang and rolls 467rwhp
Stock LS6 intake, TB, and stock water pump
http://forums.corvetteforum.com/show...979&forum_id=1
** Doesnt know why
ET Performance CNC'd LS6 heads 2.055 valves, 309CFM @ .650 lift (intake), not milled
HPE S cam, 238/242 .608/.612 115LSA
Kooks 1 7/8" headers, 3" x pipe
chamered 3" mufflers
borla straight pipes
vararam
LS6 intake
new plug wires
new plugs
160 thermostat
spec 3 clutch
billet steel flywheel
dte brace
I thought I read (but can't find the post now) that the low dyno was done with like 15psi in drag radials, and the higher dyno had 30psi in the same tires.
<edit>Found it: http://forums.corvetteforum.com/show....php?t=1294436
Don't know if that's worth 57rwhp, but it's got to be worth something.</edit>
Oh, come on guys, ET heads aren't that good, don't you guys know that it's all hype? There's NO WAY they could put out good numbers, it's just hype.
Glad someone brought this topic up. One more notch in the belt for ET's proven performance.
vararam
LS6 intake
new plug wires
new plugs
160 thermostat
spec 3 clutch
dte br
How did he manage P/V clearance with that cam/head package. Seems like a close call to me!
vararam
LS6 intake
new plug wires
new plugs
160 thermostat
spec 3 clutch
dte br
I don't see that cam producing any p/v issues with that setup depending upon where the ICL is. If that car pulled that far chances are the ICL is very late and would clear just fine cause of the wide lsa.
