Torquer V.2 cam???
Torquer V.2 cam???
I just ordered the TSP Torquer V.2 cam and the PRC spring kit, 3400 stall,LS6 intake, B&M tranny cooler,Ported LS6 oil pump. I was wondering if I need bigger injectors? Mines a 2000 so i think it has 26lbs stock?
Does anybody with a big cam run on stock injectors? and how safe is it?
in the future i will be spraying a wet 100hp shot (ZEX) too.
I just installed that cam with a set of PRC heads. Haven't tune it yet on the dyno, and haven't beat on it yet, still breaking it in. But I would think the stock injector will be fine. If not I will let you know since our cars are same years.
I think you'll be okay. My V.1 Torquer is fine with stock injectors, but since I added the Fast 90/90 the duty cycle has been going to 85% at WOT, so I'll be upgrading those when I install my heads.
99% of the time i won't be spraying only at the track. and i only make it to the track a couple times a year.
its just if i'm going to swap the intake, i'll do the injectors now
but if i don't need them then i can wait,untill i get some heads
thanks for your help
