Question on heads and cam purchase
Old 03-19-2006, 08:31 PM
Slow00ls1T/a's Avatar
Default Question on heads and cam purchase
is this everything i needALL NEW PRC LS6 CNC Ported Heads
Item# 199-PRC1.0LS6 $899.99
Valve Springs: | Comp Cams 918 Springs $150.00
Valve Options | 2.00"/1.55" Standard Valves $0.00
________
$1,049.99 $1,049.99
Texas Speed & Performance Chromemoly Pushrods
Item# 25-7400 $96.99
Pushrod Length: | Standard 7.400"
Texas Speed 228R Camshaft
Item# 25-228R $379.99
Basic Heads & Camshaft Bolt & Gasket Kit
Item# 25-HCKIT $149.99 $149.99
GM LS2 Timing Set
Item# 28-LS2timingset $88.99 $88.99
TSP Ported LS6 Oil Pump
Item# 25-12586665M $129.99 $129.99
thanks
Old 03-19-2006, 09:52 PM
10 Second Fun Car
jlrz28's Avatar
Looks good!
Old 03-19-2006, 09:56 PM
yak
yak's Avatar
just rmamber new oil and coolant, some locktite and anti seize for the spark plugs.
Old 03-19-2006, 09:59 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Looks fine to me!
Old 03-19-2006, 10:33 PM
thanks just wanted to make sure
Old 03-20-2006, 04:44 PM
Bill Bowling's Avatar
Talking
Do you have the pump o-ring? I was not sure if it is in the kit. Do you have new value seals?
Good luck.
Bill
Old 03-20-2006, 10:00 PM
marcus769's Avatar
Dang, that **** adds up!
Old 03-20-2006, 10:08 PM
Studytime's Avatar
Is your price on 918s recent? If so, from where?
Ben
Old 03-20-2006, 10:59 PM
heavymetals's Avatar
I wouldn't order pushrods until I had measured what I needed.
My $0.02
Old 03-20-2006, 11:43 PM
it is from texas speed yes with 918
