2.02/1.60 Stainless Valves
Old 04-18-2006, 12:44 PM
67Firebird455's Avatar
Default 2.02/1.60 Stainless Valves
Lookin to buy a set of Ferrea 6000 Stainless valves, but not sure what you guys think of going with the 2.02/1.60's vs the stock sized 2.00/1.55's. With the larger valve, after machining the seats to accept those valves, will I be running the head too thin between the seats (cracking)? Not sure if it is worth going up a size, for only a $10 difference. Would love to hear what you guys think?
Old 04-18-2006, 01:05 PM
Nasty N8's Avatar
Deffinatly worth it if the heads are ported to match.
Nate
Old 04-18-2006, 01:11 PM
Mike@TEA's Avatar
Stock seat ring sizes are 2.040 on the intake and 1.57 on exhaust. Your valve job/seat will be on the aluminum with the 1.6 valve. The 2.02 will work fine, as for valve spacing there is lot of room between the 2. You should put an oversize seat in the head if you want to use the 1.6 and make it right.
Old 04-18-2006, 03:04 PM
Thanks for the heads up. I think I'll stick with the stock-sized valves for this setup for now. The mrs. is already all over my butt for spending so much on the car after grenading the stock shortblock (gotta love FI). Thanks guys... appreciate it very much.
Old 05-03-2006, 12:52 AM
Bought a set of Ferrea 2.02's, will the manley 1.575's work with this without installing a new seat? Don't want to get too close to the head, by leaving too little seat material. Again, this is going to be for a moderate-boost application (12-15#)
Old 05-04-2006, 12:19 AM
Anyone? Will the 1.575's work with the 2.02's I just purchased without installing new seats?
Old 05-04-2006, 09:40 AM
moeZ28's Avatar
i just did manley 2.02s and 1.575s and as far as i know there is no issues with the 1.575s. looks like plenty of seat material left.
Old 05-04-2006, 11:03 AM
Thanks for the response, guess I'll order my 1.575's and see how it works out.
Quick Reply: 2.02/1.60 Stainless Valves
