MAP connector in the back of intake is loose!!
Is this a problem? The MAP sensor wiring connector in the back of the intake is loose. I can move up and down, and rotate it, and it moves in and out. What seals the back of the intake. It feels like it is ready to fall out. What holds it in there. Do I need to take it out and fix something???
Shouldn't be as long as it isn't coming out...sits in some kind of rubber bushing. Some people put a bead of RTV around it after doing intake swaps...but if it hasn't come off or has a vac leak, you are fine IMO.
That's what concerns me, is it leaking vaccum, how can I tell. I'm trying to tune the ECU and geting some funny numbers. I can't hear any leak. How else can I tell if it is leaking.
LS6. I remember looking at it before I put that intake on, and I really did not understand what was holding it in there. Is there some kind of O ring? But there is no clamp or holder, it just sits in there??
There is a orange corragated gasket like the ones used for any of the other electrical connectors. On my FAST intake, I had to use some sealer in conjunction with the gasket, the hole on the intake is slightly too big.
Does that gasket seal off the vaccum?
Is that just a seal for the connector, or is that the actual vaccum seal for the intake pressure? The big question is do I need to take off then intake and fix this thing, or is it OK for it to be loose? Is it a possible vaccum leak.
There should be a plastic clip moulded on your intake holding your MAP in place. If it is broke off you can use TWO plastic tie wraps crossed over and around MAP to hold it in place.
No worries friends. It was just the connector, the MAP sensor is solid. The connector is clipped onto the hose fitting for the power brake. The connector moves up and down. The hose fitting is part of the sensor, it's all one piece of plastic. If the plastic fitting for the brake hose moves, you have trouble. I took the intake off and put silicone sealer around the sensor to make sure there are no leaks.
