Camshaft install tool??
I was going to order this from Thunder Racing, but they are out. What have you guys done to get the hydraulic lifters in place while you take the cam out?? I don't just want to let friction hold them in place. I was thinking about the pen magnet idea, but I'd really like that tool. Does anyone know what diameter that tool is? I was thinking about just using some round rod? Any ideas on what to do?
Originally Posted by sidewayz28
we bought some rod from home depot.. dont remember the size exactly ill try to find out
Originally Posted by Rothman
I'm confused. A broom stick is definatley not 5/16.
Seriously, any cut to fit 5/16" diameter stick will work, wood or metal.
5/16 steel rod will need to be ground down to work on the pass side. At least this was the case with the cars i've done so far. I've heard brake line works better.
Originally Posted by chimazo
I am 99% sure you use a 22" long 5/16" dia. wooden dowel that you can buy from any Home Depot, or you can just ruin the broom you already have.
Originally Posted by V6 Bird
I definitely dont recommend WOODen dowels...Get the metal...They wont snap..I did have to shave off the passenger dowel on one side to give it a flat spot to slide it in...Once in i turn them to look them in place. Both of mine are sharpened on the end going into the motor to a point...
luckily for me the guy who produced them JPR installed my cam and valvetrain.
worst case senario (spelling) get metal dowels
-brandon
I bought a 5ft section of 5/16 brake line from the local auto parts store for 6 bucks cut it down to like 24 inches i believe and stuck it in there worked perfect. Make sure you use a little oil on it, it goes in better.
