Car will not idle after heads/intake install. HELP!
I started my car up yesterday after heads/intake/fuel/clutch and other stuff and it ran great, idle was perfect. I also started it again today, but I just went to start it again after changing the oil and it will not idle, just quits... I adjusted the idle screw just so it stays running, idle is very rough..up and down. Any ideas??? It ran gread hours before I changed the oil, the only other thing I did was re-assemle the interior, could I have pulled a wire there??
I did not check it, but I did my calculations and read up on the issue and there should be clearance with the mild cam I have and .051" gaskets, I've seen people with bigger cams have no issues with these heads. Also I heard they set up like stock.
