oil pickup tube question
you guys think this dent in my oil pickup tube is an issue? this is the end that goes into the oil pump. it is only at the end and is very small, also it is not at all bent in the o ring area.
Originally Posted by orangeapeel
I think that you should be fine with it. How did it get bent though?
honestly i have no clue. and i cant like bend it back with pliars, somehow it got tremendous force put on it. it might have been while the motor was appart or in transit.
Originally Posted by SDMForever
they are not expensive replace it! Is it worth taking a chance of depriving your engine of oil and then it seizing up. I say replace it. whats 30 bucks
well there are like 10 things that you can look at in a motor and be like "why dont i do that while im in here" result is you go way over budget.
i think that im going to try to get an expander
