whats the difference in a solid roller cam?
Solid rollers also require regular valve lash adjustments.
A solid roller can go in a 346.
It uses solid lifters, not hydraulic lifters that can adjust play. You use adjustable rocker arms to adjust play.
Solid roller allows you to run just about whatever spring pressure you want with out having to worry about over coming the lifter like you do with a hydraulic roller. This allows you to run more aggresive cam profiles and turn them considerably faster. They will require an adjustable valvetrain and periodic maintenance (valve adjustments). The main reason for their lack of popularity is that (as mentioned before) they are rarely required for the LS1's and most people do not like having to adjust valves on a semi regular basis.
Check out Phils thread here: https://ls1tech.com/forums/generation-iii-internal-engine/577444-more-346-et-240cc-11-degree-progress-10-7-131-n-2500-a.html
He runs a solid roller 346 setup...
Dan
Dan
