crank bolt
Never reuse the Balancer bolt. It is "torque to yield" which means it is "stretched" the right amount to maintain constant pressure.
Same for the head bolts.
gm head bolts are good, but there a one use item. i just bought arp head studs as the're reusable, studs make things alil easier etc. i also got an arp crank bolt, just got a new crank bolt with my ud pulley , but i had to take it off to do a cam swap, so most likely i will have to again later.
Originally Posted by cjg454ss
ok thanks, are gm head bolts any good, i dont have the funds for arp at the moment. was wondering if a new set of gm bolts would work and if so, is there a torque spec?
