how to tell what ZO6 LS6 cam it is 2001 2002? or what???
Old 10-16-2006, 03:09 PM
Restricted User
fenix99's Avatar
Default how to tell what ZO6 LS6 cam it is 2001 2002? or what???
so i buy a used LS6 cam, havent installed it yet at all it looks very VERY nice and is in awesome shape for being used. Looks kinda new actually but i wanted to know how i can tell if its an LS6 cam(and if its a 2001 LS6 or 2002 LS6, and yes there IS a difference with lift and LSA if i remember correctly!) It still has all serial #'s all that crap engraved on it so im guessing someone can tell me if they know anything about the numbers. I have a STOCK LS1 cam out of my 1999 LS1 laying around and tried measuring the lobes with a millimeter measuring thing and they came out very similar if anything the "LS6 cam" lobes measured to be smaller than my stock LS1 lol.... WTF?? someone please shed some light i dont feel like going to the dealer right now its kinda far THANKS!!!!!!
Old 10-16-2006, 03:14 PM
12secSS's Avatar
Post up the numbers, that is one way we can help. Or search on the internet for those numbers.
Old 10-16-2006, 04:41 PM
Hugger's Avatar
If I remember correctly it will have the last 4 digits of the part number written on the end of the cam.
Old 10-16-2006, 04:52 PM
Restricted User
fenix99's Avatar
at one end of the cam it has a little barcode looking thing printed on it just like my factory LS1 cam had and it has three rows of numbers and one letter
look like this:
5308
S 09
3044
Old 10-16-2006, 04:59 PM
hammertime's Avatar
how are you measuring? the smaller base circle diameter should be a start, otherwise 2001 cam had .525 lift, 2002+ had .550 lift.
Old 10-16-2006, 05:13 PM
GR33N GoblinM6's Avatar
what would better .. the 03+ LS6 cam or the LS6 Hot cam... if you had to choose between the 2...
Old 10-16-2006, 07:25 PM
Restricted User
fenix99's Avatar
i know the lift and everything of the two LS6 cams (01 and 02+) but i need someone with knowledge of the serial #'s engraved on the actual cam. Because from physically measuring some spots on the cam and comparing it to the stock LS1, i see very minor almost no difference, but maybe my measurements aren't correct or maybe the physical diff between the two cams are just that minimal
---OH and im measuring the lobes on each cam, measuring the tallness of each lobe off the shaft, you know the peak on each section and im doing the same with the stocker.. hope somebody can figure this out for me. If not its off to the dam dealership and pray some idiot in the parts/tech department can find anything to do with those lil serial numbers on the cam
Old 10-16-2006, 08:12 PM
oange ss's Avatar
just measure the height of a cam lobe and multiply by 1.7, there's a big enough difference between the two cams to not confuse them
Old 10-16-2006, 08:34 PM
2xLS1's Avatar
look like this:
5308
S 09
3044
That is the 02+ LS6 cam. GM part # 12565308
Old 10-17-2006, 12:35 AM
Restricted User
fenix99's Avatar
sweet thanks for the info guys i will double check the measurements and make sure at the dealer that what i have is what i originally though i had. Imma also look up the part #('s) for my stock 1999 LS1 cam as well to see if matches up and 2 see if i actually do have the 02 LS6. thanks again latR
Old 10-17-2006, 02:17 PM
12secSS's Avatar
The proper way to find the lift of a cam using calipers is: Measure the Largest point of the Lobe (Lobe Height), Subtract the Smallest point of the Lobe (Base Circle), Multiply that value (Cam Lift) by the Rocker Ratio (LS1 = 1.7). This gives you Valve Lift.
Example: 1.0568" (Lobe Height) - .7480" (Base Cricle) = .3088" (Cam Lift) X 1.7 (ratio) = .525" (Valve Lift)
Old 10-17-2006, 04:52 PM
Restricted User
fenix99's Avatar
i was wondering on the formula for that, thanks
Quick Reply: how to tell what ZO6 LS6 cam it is 2001 2002? or what???
