Comp Cams R-Series Hydr. Lifters 875-16
Old 10-18-2006, 08:06 PM
mvvette97's Avatar
Default Comp Cams R-Series Hydr. Lifters 875-16
are these a good set of lifters?
Old 10-18-2006, 08:09 PM
madmaxz's Avatar
just stick with stock GM, OEM comp cams, or the new LS7 lifters from gmparts direct or sdpc
Old 10-18-2006, 08:10 PM
mvvette97's Avatar
you know what the pt# is for the oem comp lifters?
Old 10-19-2006, 12:49 AM
mvvette97's Avatar
do the R series not work very good or what?
Old 10-19-2006, 07:16 AM
madmaxz's Avatar
850-16 yeah comp r's are too noisey
Old 10-19-2006, 07:25 AM
Cstraub's Avatar
Just get a set of Morels from one of the board sponsors and buy your last set of lifters.
Old 10-19-2006, 02:25 PM
ThunderStruk's Avatar
Hands down the best LS1 lifter
Old 10-19-2006, 03:22 PM
jegten's Avatar
are they really that noisy?
but, do they still work fine?
thanks
Old 10-20-2006, 08:36 AM
ShiznityZ28's Avatar
Comp r's got a bad name form some guys who did not know how to set up preload. I ran them for 2 years to 7500 no porblem but still not the best lifter but do work well if set up corrrectly.
Old 10-20-2006, 06:23 PM
Azrael's Avatar
The Comp OEM style lifters are 850-16 (just clarifying the post above)...
Old 10-20-2006, 10:42 PM
LS1Tech Sponsor
Slowhawk's Avatar
They actually work great for high lift Cams. As for noise,some people just don't know how to set them up.We've done 6 cars with them--all quiet as stock.
Old 10-21-2006, 09:51 AM
GrannySShifting's Avatar
same here. mine were very quiet. most guys put to much preload on them in my iron block we set them up at 0- .001 preload cold makes ~ .009 hot. on the aluminum you need a hair more cold to get the same hot but we normally just set them hot .
Old 10-21-2006, 06:03 PM
Camaro99SS's Avatar
Comp R's and stock rockers are a no-no. The R's don't like nearly as much preload as what the stock torque specs give. This is why they got a bad reputation among LS1 and LT1 guys.
Jason
Old 10-21-2006, 06:59 PM
Collections Hold
Cary@Perf-Induction's Avatar
Default comp r
I have them in my engine, I love them. You do have to be very close on your preload though. I run them about .005 on an iron block. aluminum about .010
Old 10-23-2006, 11:23 PM
jegten's Avatar
i am going to buy a pr length checker to get the length i need.
any feedback/input/advice/suggestion? please.
meaning, for the preload, once i find the exact length.
thanks, guys.
Old 10-24-2006, 09:43 AM
NA$TY-TA's Avatar
Comp R's here and doing fine......
Old 10-24-2006, 11:15 AM
eamador11's Avatar
Same here...done right by ECS
Quick Reply: Comp Cams R-Series Hydr. Lifters 875-16
