Another Cam ?
Old 10-24-2006, 09:30 AM
GreenBlood's Avatar
Default Another Cam ?
Whats a good cam to run on an LS1 with stock heads, and and LS6 intake...There will be a 3200 stall converter and transcooler already in place and I would be buying a a valvetrain kit along with the cam to make sure the engine can handle it...What would be the ideal size cam, and would you be able to here a lope at idle? I really like that sound, but I don't have the money to dump into heads and all that stuff, I am just a power hungry college student, so I want to make the most of my budget...Thanks
Old 10-24-2006, 10:31 AM
N4cer's Avatar
There's quite a few great cam-only cams out there. If you want help in that decision, check the drag racing forum below. It tells fastest cam-only times.
The cam-only locals are happiest with the G5X2, G5X3, and MS3. I watched a cam, header, cutout MS3 A4 put down 389hp on the dyno a couple of weeks ago. But I think your goals will determine your cam more than anything.
Do you want a top-end (high revs only) beast? Or do you prefer a wider, lower powerband?
Old 10-24-2006, 01:34 PM
GreenBlood's Avatar
Probably wide and low, this will be a daily driver with a little fun on the street...HAHA...Will only see the track once in a while...
Old 10-24-2006, 05:52 PM
GreenBlood's Avatar
bump...
Old 10-24-2006, 06:11 PM
Retired Street Racer
Matt D's Avatar
TSP Torquer 3 for your application.
Old 10-24-2006, 09:02 PM
GreenBlood's Avatar
Any other ones, that seems kinda big for stock heads and only a 3200 stall...
Old 10-24-2006, 09:24 PM
rickyracer25's Avatar
Here I go whoring 4 texas speed click here This should be great, good with the stall and good DD cam just make sure you get a tune w/ your A4
Old 10-24-2006, 09:29 PM
2001bluerata's Avatar
I'd go bigger than 224 esp. w/ a 3200 stall. I'd say the TSP 233/239 would be great, awesome lope, and the power you'll love!
Old 10-24-2006, 09:36 PM
GreenBlood's Avatar
safe to run without heads or ported throttle body for more air intake? (233/239)
Old 10-24-2006, 10:04 PM
It's what I have, stock heads/TB. And ur sig says u already have the LTs and exhaust to go w/ it. Go w/ it you'll love it. I have a m6 too, and it drives good, you'll definitely need a tune also.
Old 10-25-2006, 03:20 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
230-236 range most likely will work fine with that converter.
Old 10-25-2006, 07:28 AM
Beasst8's Avatar
There are people running the MS4 (239/242) on stock heads and intake.
Old 10-25-2006, 11:44 AM
mattraypharbor's Avatar
im runing 23*/24* 60*/61* 113lsa on stock heads though a 3500 stall and 4.10s i saw allmost 400rwhp with a crapy tune ...for all of you who know jeremey formoto hes going to tune it and it should put down more...
Old 10-25-2006, 03:15 PM
Old 10-25-2006, 03:37 PM
GreenBlood's Avatar
nice numbers mattray, how's the drivability on that?
Old 10-25-2006, 05:38 PM
Go 233/239, you won't go wrong!
I don't think I would go w/ ms4 unless I had heads, just my .02.
Old 10-25-2006, 11:55 PM
not to bad a lil bucking but its ok
Old 10-25-2006, 11:58 PM
heres a lil vid link
http://videos.streetfire.net/search/...58000000ec.htm
Old 10-26-2006, 12:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Lol @ the *'s. Looks like an MS3.
Old 10-26-2006, 08:13 AM
custom grind
