Can I make 400hp with 228R??
Do you guys think i can get 400hp with the 228R cam from TSP?
The supporting mods will be.....LT's/ORY thru a cutout in the I-pipe, LS6 intake mani, lid,filter,bellow,MAF,CAI, P&P TB.
So what do you guys think?
Thanks for you input
i was only in the 38x range but i'm sure with a ud pulley and great tune 39x was possible.the 228 is a great all around cam that peaks fairly early so you don't have to wind it to the moon .
Originally Posted by TXZ28LS1
im pretty sure you will be close. $hit, thunder racing didi 390ish with a 224 cam. so i can see it doable.
I have the TSP228R. I havent dyno'd it, but this is what I figured.
I had all the bolt ons and a TR224 cam, and it dymo'd at 370RWHP. The 228R is good for maybe 8-10 RWHP more according to TSP. So lets say now im at 380RWHP and Ive added AFR heads milled .20 off which I figure are good for 40 RWHP. So I figure I have 420 RWHP, but my tune is not razor sharp and the tuner thinks it's a bad cam to tune. This is his quote:
"As I have stated in past posts I am not a fan of more duration on the intake and same spec cams intake/exhaust. Its been proven time and time again you need to run mininum of 4 degrees more on the exhaust to get the combo to sing. I've advised many people not to use certain cams and they end up unhappy".
The car bucks at low RPMs in any gear, but it's most evident in 1st car between 1500 and 1900 RPMs
