AFR 205 CC question.
I tried serching for this and no luck. Is there a site or chart where it shows how much you need to mill off to get a certain cc combustion chamber? Or do you just mill a couple thou and keep checking it?
Originally Posted by Revson
So are you guys saying that a file and a chisel won't work???
Well the thing about milling heads is that you can't take a few cuts to get the speed and feed set right. Mine are milled .024 and I am sure that wasn't acheived by taking 3 or 4 cuts. You better have that **** dialed in before the cutter touches the aluminum, cause it will be too late afterwards.
This is great info. I PM'ed Mamo about this yesterday. Out of the box the AFR 205's are 66 and mine are milled .020 which means I am at 62.67. Very nice!! Need a little a little more milling for the G5X3 then.
Thanks,
J.R.
Thanks,
J.R.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Thanks,
J.R.
Thanks,
J.R.
If you would have looked at the company that sells these heads website, you could have found the answer. Plus you get a lot more info
http://www.airflowresearch.com/205_mongoose.php
Angle Mill (milling available) .008" per cc
Flat Mill (milling available) .006" per cc
LG says you don't have to flycut but I am going to just to be safe.
AFR 205 milled .030 to 59 cc with .040 gasget, requires flycutting. I'm 99.99% sure of that. (I leave a little to Lady Chance)
https://ls1tech.com/forums/showthrea...highlight=g5x3
Post #8 from Louis
59cc AFRs, G5X3, .040 gasket, no need to flycut.
Post #8 from Louis
