Jesel Mohawks valve covers?
Old 11-19-2006, 04:02 PM
John02SS's Avatar
Default Jesel Mohawks valve covers?
Anybody had any luck gutting the stock valve covers when running the jesel j2k mohawks? The article in GM High Tech did this and it seemed to have worked. I want to keep my coil brackets on the cover as I don't care for the long wires when it is relocated. Thanks!
John
Old 11-20-2006, 07:51 PM
John02SS's Avatar
Anyone?
Old 11-20-2006, 08:16 PM
1997bird's Avatar
What type of heads are you useing? I have did this modification.
Old 11-20-2006, 10:08 PM
jbuckweiser's Avatar
I have the GMPP Heads and the baffles had to be removed for the Jessel SS rockers.
Old 11-20-2006, 10:10 PM
John02SS's Avatar
I will be running TFS 215's with them. They have the rocker rail raised a lil, so maybe they will fit.
Old 11-20-2006, 11:20 PM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
stock heads and AFRs required a 1/2" spacer. I've run both with the Jesels.
Old 11-20-2006, 11:38 PM
1997bird's Avatar
Just follow the pic's and you will be fine. This shouldn't take you more than a 1/2 hr. The most critical part will be when you go to grind the driver side valve cover by the PVC grommet. Take your time so that you don't grind through the valve cover. Constantly be feeling the thickness of the cover where it sqaures off for the PCV from the rounded part of the cover. Because once you get the top of the rouded stud (on the inside of the cover next to the above metioned corner) removed it gets real thin quick.
Old 11-20-2006, 11:58 PM
John02SS's Avatar
1997bird, What heads and rockers are you running? Thanks.
Old 11-21-2006, 12:06 AM
1997bird's Avatar
Racing Head Service's 225cc int. runner head that has a .500" raised valve cover with Jessel SS 1.7 ratio rocker's.
Old 11-21-2006, 05:38 AM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
ET 255'S need a spacer to run the J2K's
