engine bore?
Old 11-22-2006, 11:24 AM
SSdreamz's Avatar
Default engine bore?
ok my engine is out, and dissassembled. im looking at a 383 stroker kit. this kit specs out at 3.905 bore. this im told can done with just a hone. but when i mic'ed it out i need to take out .0074 of my cylinder wall to get this bore of 3.905. granted, once i receive the actual rotating assembly, ill measure everything once again before i get the machining done, but what my question is.... .0074 seems alittle much to do with just a hone. maybe a few swipes with a bore and then a finished hone. so can our blocks be bored? cause im also told that they cant be bored. so whats the real deal here? also, i need to find a head plate to bolt on the block to get the most acturate bore measurements i can. where can i find one? anyone want to help me out on this head plate? im sure we can work something out. one last question... anyone know where i can get all the clearances i need to assemble the bottem end?
Old 11-22-2006, 08:42 PM
SSdreamz's Avatar
t.t.t.
Old 11-24-2006, 01:31 PM
SSdreamz's Avatar
no one??????
Old 11-24-2006, 03:40 PM
JPH
JPH's Avatar
Bhj/goodson Should Make One By Know. Your Local Machine Shop Should Have One Also, Or Can Probably Borrow One. To My Knowledge You Should Be Able To Go .010 With Your Bore At The Most. As Far As Clearances, Check Ls1/ls6 Performance Books, Or Just Ask Any Engine Builder, Most Run Around What Gm Had Them Set At Anyway.
Old 11-24-2006, 10:24 PM
66deuce's Avatar
i read something awhile back that said you could use a TQ plate from a small block ford if the machine shop didn't have an LSX specific plate.anybody know if this is true?
Old 11-24-2006, 11:35 PM
Mikey 97Z M6's Avatar
Originally Posted by SSdreamz
no one??????
I see that your car is a 99' model year, but it could have a carry over 98' style block in it. You can tell which block you have by looking that the second picture down in this link: http://www.automotiverebuilder.com/ar/eb040538.htm
If you in fact have a 98' style block, the absolute MOST you can hone it is 0.0050" before you'll start getting too thin on the cylinder liners. The early (97-98) LS1 blocks had super thin liners. If that's the case, you'll need a 3.903" piston, as the stock bore is 3.898".
Mike
Old 11-25-2006, 02:12 PM
SSdreamz's Avatar
good info, ill check to see what block i actually have
Old 11-28-2006, 08:14 AM
SSdreamz's Avatar
my block is a 99. so anyone know if the small block ford plate will work like 66deuce says?
Old 12-01-2006, 08:42 AM
SSdreamz's Avatar
t.t.t.
Old 12-01-2006, 12:18 PM
MiketurboLS1's Avatar
the block can be bored up to .01, so obviously you wouldnt have a problem getting your .0074. not too sure about the SBF Torque plate, i know they can be used on the LTX platform, but im not a 100% about the LSX, ill try to do some research for ya. I'll try to get you the clearances soon, dont have them on hand.
Old 12-01-2006, 07:53 PM
SSdreamz's Avatar
i really appreciate it thanks....anyone else want to chime in on the SBF torque plate working on the LSX?
Old 12-07-2006, 07:50 PM
SSdreamz's Avatar
any news yet miketurbo?
Old 12-08-2006, 09:16 PM
Learnhead's Avatar
I'm going to borrow the thread for a minute, hope you don't mind.
So you can safely bore a '99 .01 over, making the bore 3.898+.01 = 3.908. ?
I have a 99 and will be running about 10 psi. I just want a big enough bore to fit the smallest forged pistons that seems to be available which are 3.905. Will this be safe or do I need to resleeve?
Old 12-09-2006, 12:14 PM
DuronClocker's Avatar
3.905 pistons work in a 3.905 bore. The piston is actually smaller than that. When they are advertised as 3.903 or 3.905, they are designed to work in a bore of that size. You don't match a 3.905 piston to a 3.908 bore.
Old 02-13-2007, 02:40 PM
12 Second Truck Club
TURBHOE's Avatar
so can you use a sbf torque plate? anybody figure this out?
