Best Way to Clean Heads???
Old 11-28-2006, 12:47 PM
pennys58's Avatar
Default Best Way to Clean Heads/Tuning Question???
I just bought a pair of used MTI stage II heads with 1,000 miles on them from a fellow board member. I was wondering what the absolute best way to clean these heads would be..(do's and dont's)? Please let me know, I will be having them installed within the next week or two so Id like to have them ready to go (they are currently lightly coated in oil by the previous owner). Thanks for the help.
Old 11-28-2006, 12:59 PM
GuitsBoy's Avatar
brake clean to get rid of oil, acetone and a plastic sponge to get rid of gasket material.
This stuff can dry out your seals so either be ready to replace them, or be very careful how you use them.
Old 11-28-2006, 01:03 PM
Studytime's Avatar
Best way? Bead blast them with glass beads inside and out. Then you'll need to rinse them in acid ("aluminum brightner") to get all of the sand out of the heads. After that, hit the intake gasket surface with a scotchbrite pad and deck them. Don't forget touching up and blending in your valve job too.
Or you could just take the springs out and wash them with degreaser and hot water. Blow dry with compressed air and reassemble.
Ben T.
Old 11-28-2006, 01:57 PM
pennys58's Avatar
Thanks guys, Ill give it a try!
Old 11-28-2006, 02:10 PM
pennys58's Avatar
Also, my car is already tuned for my cam/bolt-on set up, how soon do I have to get my car tuned after I get these heads installed? This is my daily driver, so it may be hard to get it all done at once???? Let me know what you think.
Old 11-28-2006, 03:03 PM
pewter 01 SS's Avatar
if you have the money get it tuned asap.. your a/f is going to change again and the last thing you want is to go lean and blow something.. specially it its a daily driver then for sure i would tune it quick.
Old 11-28-2006, 03:05 PM
pennys58's Avatar
Thats what I was thinking, Ill line something up with getting the car tuned asap. I appreciate your post!
Old 11-28-2006, 03:19 PM
Quickin's Avatar
Let a good head shop clean and check them out.
Old 11-28-2006, 05:34 PM
Ferocity02's Avatar
I'd say disassemble them completely and wash them with a good sponge and some degreaser. They don't need to by too clean, they will be black with soot after 10 seconds anyways. You mainly want to remove all of the old gasket material.
Old 11-28-2006, 07:03 PM
Lurius's Avatar
Take'm to a head shop, get a valve job done lol, that wya they are cleana nd you can have the pro's measure everything make sure theres nothing wrong with'm.
-Lurius
Old 11-28-2006, 07:22 PM
pdd
pdd's Avatar
cant you just clean the gaskit crap off good and clean all the oil of the bottom of the heads and valves and put them back?
Old 11-29-2006, 07:53 AM
pennys58's Avatar
I am going to take them to a head shop just for them to get looked over. There is no head gasket material on the heads, the previous owner cleaned them up and coated them with oil. I just need to clean off the oil so I can get them on the car. Thanks for the advice everyone.
Old 11-29-2006, 09:47 AM
Studytime's Avatar
A clean-up mill still isn't a good idea. They could be clean, but not perfectly flat. If you're running a MLS gasket, they would probably be fine to put on how they are just cleaned up well.
Ben T.
Old 11-29-2006, 10:34 AM
DONAIMIAN's Avatar
If your in a hurry/need them on go with carb cleaner. If you have a little cash and some time, take it to a machine shop and have them cleaned and gone through.
Quick Reply: Best Way to Clean Heads???
