Katech Rod Bolts
Old 12-03-2006, 09:15 AM
chopperloco's Avatar
Default Katech Rod Bolts
Where do we get the best deal on them?
Thanks-Dominic
Old 12-03-2006, 09:59 AM
PREDATOR-Z's Avatar
Katech, maybe SDPC
Old 12-03-2006, 10:01 AM
GuitsBoy's Avatar
I might be wrong, but arent they only available direct from katech? If youre worried about price, there are far more affordable options than the katechs. However, if you want the very best available, those are them.
Old 12-03-2006, 10:11 AM
ls1muscle's Avatar
You can call Katech to order them or you can order them off their ebay link, same price.
Old 12-03-2006, 11:08 AM
...with cheese.
Armageddon's Avatar
What's Special about them?
Old 12-03-2006, 11:14 AM
GuitsBoy's Avatar
Highest tensile strength. Exact replacement dimensions and weight. Plus they make the outright claim that you can direct swap and go.
...with cheese.
Armageddon's Avatar
This is what I found on Katech's site.
Gen 3 / 4 Rod Bolts Extensive testing by Katech for GM’s LS1 ASA engines showed the production rod bolt to be the weak link in the stock bottom end in the LS1 engines. Our rod bolt is the best you can get and fits production connecting rods without having to re-hone them to size.
These direct replacement bolts are made from H-11 material for extremely high tensile strength with threads rolled to J-graded specifications. To install the new bolts, simply remove the old bolts and feral that hold them in the rod cap. Then insert the new rod bolts, apply a light coating of supplied lubricant to the threads and torque to 50ft.lbs. Using the Katech rod bolts will increase your engines RPM and Horsepower potential.
$153 a set
ARP Rod bolts, which are the ones I ran are about $90 a set. They were heavy though. Are Katech's lighter?
Old 12-03-2006, 02:03 PM
Cop Car's Avatar
ends up being like $167 to your door
just call katech directly, you will have them in a week or so
Old 12-03-2006, 02:05 PM
Black X's Avatar
For what its worth, I did a set of ARP 2000's as a direct swap no re-size and I have 7,000miles and 40 quarter mile passes on my motor without any problems.
