Dart 205 or 215 for DD?
Old 12-19-2006, 04:09 PM
Bill Bowling's Avatar
Talking Dart 205 or 215 for DD?
For a daily driver I was leaner toward 205cc runners but 225's seem to come up for sale more often. If the heads were cut say .080 on the 225cc would it be hard on a daily driver? Would it be too peaky?
Thanks,
Bill
Old 12-19-2006, 04:11 PM
ThirdGenLS1's Avatar
depends on the cam, with the cam in your sig i would prolly go with 205's
Old 12-19-2006, 04:20 PM
I was planning on keeping the 233/233. I like it.
Thanks.
Bill
Old 12-19-2006, 05:48 PM
vettenuts's Avatar
Not sure of your PTV with the cam, but the 205's and the 225's have different size valves if that is a concern at all.
Old 12-19-2006, 06:03 PM
hissin'98's Avatar
205's will give you more bottom end over the 225's. I'm planning on going with the 205's as well for dd. If I was to run the 225's, it'd be on a bigger motor with more cam.
Old 12-19-2006, 07:06 PM
duece_bigalo01's Avatar
I have the 205s in my car with the MTI C1 cam and I love it. No complaints here. And its my daily driver.
Old 12-19-2006, 11:22 PM
I would go with the 225's if you had a cam with more lift like say the lsk lobes so you could take advantage of the flow past .600 inchs but with the torquer i defintally say the 205's. As for PTV you'll be perfectly fine with stock gasket thickness but if you are pulling th heads i would recomend running .040 gaskets to up the DCR but even with that i think you'll be fine on PTV, but measure just to make sure
Justin
Old 12-19-2006, 11:38 PM
Studytime's Avatar
Do you have any numbers from this Dart 205 / C1 combo?
Ben T.
Old 12-20-2006, 07:24 AM
Sigforty's Avatar
When you say the heads are cut 0.08 do you mean milled? I know mine have been milled a little like 0.02 and my compression was around 11.3 to 11.5.
Old 12-20-2006, 04:42 PM
Nimitz87's Avatar
to the orginal poster...I was going to go with the torquer cam and the dart heads...not sure on ptv anyone know if they'll be okay?
Chad
Old 12-20-2006, 06:26 PM
vanilla89's Avatar
i have some ported dart 225's they respond good to some porting.and there milled .025
