What should I do?
Old 01-03-2007, 08:09 PM
deadmanTA's Avatar
Unhappy What should I do?
Well I bought a great set of almost new 2006 LQ4 317's and they have sat in my closet for about 2 months waiting for install. Pulled them out today and noticed the valves have surface rust starting to form on them.
So.... 1. Is it possible to hit them with some sandpaper or the dremel tool?
Or.... 2. Just get new valves? (Would the LS6 sodium filled ones work?)
Thanks in advance for any suggestions
Old 01-03-2007, 08:13 PM
deadmanTA's Avatar
Oh yeah the rust is on the bottom of them in the combustion chamber, what you see when you flip a set of assembled heads over
Old 01-03-2007, 08:15 PM
austin21's Avatar
if its on the chamber hitting them with a light sandpaper (1200 to1500 grit and wd40 )should make them look brand new as long as it not around where the stem goes through the guied you should be alright
Old 01-03-2007, 08:17 PM
austin21's Avatar
also if you do the wd40 and sanding you may have to do it a day or two in a row
Old 01-03-2007, 08:59 PM
deadmanTA's Avatar
It's just on the flat part of the valve the heads are Aluminium. Thanks, I want to take care of this now before it spreads. Should I keep a light coat of oil on them til its time to use them?
Old 01-04-2007, 09:04 PM
austin21's Avatar
yeah i would keep a light coat on there untill it was time to do the install
Old 01-04-2007, 09:13 PM
The1N_only's Avatar
just use as fine scotch brite pad and a little wd40
Old 01-04-2007, 09:23 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
simple green works good to. Try and not scor them up to bad.
