GM high-flow oil pump 17801830 vs. LS4? Help, is 17801830 just an LS6 pump?
Old 01-05-2007, 02:02 PM
Cobra4B's Avatar
Default GM high-flow oil pump 17801830 vs. LS4? Help, is 17801830 just an LS6 pump?
LS4 is on backorder... SDPC recommended 17801830... is it truly a high flow oil pump or is it just an LS6?
I want the LS4 because I'm running a Dewitts oil cooler and track the car.
Old 01-05-2007, 02:14 PM
Cobra4B's Avatar
Ok... just spoke w/ Gene Cully @ GMpartshouse.com and he verified that 17801830 is not an LS6 pump it is indeed a GM highflow pump. Also, verified that GM has no LS4 pumps.
Fark... wish somone knew if 17801830 was as good or better than the LS4.
I'm running a dewitts oil cooler and track the car so I'd like a little more pressure.
Old 01-05-2007, 02:52 PM
Cobra4B's Avatar
Anyone use this? I need to order!
Old 01-05-2007, 03:29 PM
Cobra4B's Avatar
Nevermind... Fred Beans GM has LS4 pumps in stock still! Just ordered one.
LPE, SDPC, etc.. don't have any as their on backorder.
Old 01-05-2007, 05:28 PM
JPH
JPH's Avatar
whats wrong with the melling high volume/high pressure pump. #10296
Old 01-05-2007, 06:06 PM
Area47's Avatar
why the ls4 pump?!?!
Old 01-05-2007, 06:36 PM
Irocss85's Avatar
what the hell is an LS4 pump? and how much is it?
Old 01-05-2007, 07:10 PM
Asmodeus's Avatar
I'm not telling in hopes I can order one next week before EVERYONE is out of stock and they are on national backorder!
Old 01-05-2007, 08:33 PM
SS DNA's Avatar
Whats up with LS4s ???
Are they good ? Better than ported LS6s ?
Old 01-05-2007, 09:38 PM
blkbird's Avatar
What is the part number for the LS4 oil pump??
Old 01-06-2007, 01:31 AM
Cobra4B's Avatar
12571885
LS4 is for the displacement on demand motors which need a high volume pump. A higher volume pump will flow more oil than a ported and shimmed LS6 pump, the actual internal gerotor is different.
I'm running a 7 plate oil cooler and I run HPDEs in the car so I could use the extra pressure.
However, if you car is a drag car or a street car w/o an oil cooler then you don't need one.
The melling is great, but $130ish.... I got my LS4 for $65.
Old 01-06-2007, 03:17 AM
Asmodeus's Avatar
I'm probably going to go with the GMPP high flow LS pump. Just a street car.
Old 10-18-2013, 05:40 AM
TipsyMcStagger's Avatar
I've searched for info on the 17801830 pump and virtually everything I read is contradictory. I'm looking for a stock replacement pump for my LS2 (which should be the same as a stock LS6 pump). The description on the Scoggins Dickey page for the 17801830 "high volume" pump kit says that it includes a 12586665 oil pump, which is the stock LS2/LS6 pump part number.
Half of the info on the web claims kit includes a "high volume" pump and the other half claims it's simply a stock LS6/LS2 pump.
Tipsy
Old 10-18-2013, 08:09 AM
Super Hulk Smash
JakeFusion's Avatar
Synergy has ported LS4 pumps... that's what I have.
Old 10-18-2013, 08:39 AM
usdmholden's Avatar
17801830 is an assembly which contains two items.
1) "standard" oil pump p/n 12586665, which at one time was specifically the LS6 oil pump, and now is just the"normal" oil pump.
2) o-ring p/n 12557752
17801830 is NOT an oil pump, it is a kit which includes an oil pump and an o-ring.
If your oil cooler is running in series with the engine, I don't see how a high flow pump is going to be more beneficial than a standard volume pump. If they are in series (and they normally are) 100% of the oil flow going through the cooler is also going through the engine. You would be better off with a high pressure pump to deal with the pressure drop through the oil cooler.
Pressure is determined by the bypass valve spring, not the gerotor geometry. Any additional flow provided by the gerotor, above the bypass opening point, just dumps back into the oil pan.
Old 10-18-2013, 09:10 AM
I realize that. But 17801830, which as you point out, is a kit that includes the 12586665 pump, is advertised as being a "high volume" pump kit.
If 12586665 is the standard LS6/LS2 pump that came factory installed on tens of thousands of engines, and 17801830 is a kit that includes that very same 12586665 pump, how does the "kit" magically become "high volume?"
Tipsy
Old 10-18-2013, 11:08 AM
usdmholden's Avatar
Unfortunately, I do not know why people make the decisions they make. Nor do I understand how marketing can continuously defy logic with no consequence suffered.
The best I can do is research and come to my own conclusions.
Old 10-18-2013, 11:35 AM
LOL...in other words, it's not a high volume pump included in the 17801830 "kit," despite it being marketed as such.
Tipsy
Old 10-18-2013, 02:55 PM
usdmholden's Avatar
No.
Old 10-18-2013, 07:17 PM
farmington's Avatar
for what its worth, when I put a LS6 pump in with my cam change, my oil pressure went up. Now this is is on a 50k mile great running motor. I get 60psi on the freeway hot and 45psi at hot idle with 5w-30 Mobil1. That's enough pressure for anything with normal bearing clearances. Probably too much.
Quick Reply: GM high-flow oil pump 17801830 vs. LS4? Help, is 17801830 just an LS6 pump?
