Looking for Feedback on Custom LS2 Cam
Old 01-17-2007, 04:33 PM
NoMoreFWD's Avatar
Default Looking for Feedback on Custom LS2 Cam
I have a LS2 GTO that is stock except for Kook's 1 7/8" headers with offroad pipes, LPE air intake and HPTuners. I want a cam similar to Patrick's torque cam, but for a 6.0L.
Here is what I came up with, using LSK lobes. 228/232 .639/.643 111 LSA. This gives me a DCR of 8.36 with .060" head gaskets and 8.79 DCR with .040" gaskets, leaving some room for future head swaps. I could bring the LSA to 110, this would give 10 deg of overlap and bring up the DCR. Either way I think the valve events look pretty good.
Ok, I would like to hear what you think.
Valve Lift .006 .050 .200
Intake Dur. 277 228 153
Exhaust Dur. 281 232 156
Lobe Center Line 111 111 111
Intake Center Line 111 111 111
Intake Valve Open 27.5 3 -34.5
Intake Valve Close 69.5 45 7.5
Exhaust Valve Open 71.5 47 9
Exhaust Valve Close 29.5 5 -3.3
Exhaust Center Line 111 111 111
Overlap 57 8 -67.5
Old 01-17-2007, 07:51 PM
JPH
JPH's Avatar
Overlap 57 8 -67.5
duration looks good, as well as lsa, i run a little more advance, little much on the lift in my opinion.
Old 01-18-2007, 09:27 AM
NoMoreFWD's Avatar
Thanks for the input. Anyone else?
Old 01-18-2007, 04:01 PM
NoMoreFWD's Avatar
C'mon, help a brother out. Anyone, Patrick, Predator?
Old 01-19-2007, 03:35 PM
NoMoreFWD's Avatar
I know, but this is where the cam people hang out, at least I thought.
Old 01-19-2007, 04:20 PM
greysteel_M6's Avatar
That is alot of lift. At about what lift does clearance become a problem?
Old 01-20-2007, 06:44 AM
PREDATOR-Z's Avatar
just advance it 2* if M6 and +4 if A4 otherwise good trq producer.
Old 01-20-2007, 10:27 AM
NoMoreFWD's Avatar
It is an M6 - forgot to add that.
Lift wise - it is a lot of lift. I would use the best springs I can find. Not sure if going from .600 to .650 lift is a huge deal. I know .650 is in the middle of the range according to David Vizard, based on valve size.
Thanks, I'm open to all ideas.
Old 01-20-2007, 11:56 AM
LS1 Tech Administrator
Patrick G's Avatar
Great cam if you advance it 2 degrees.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-20-2007, 03:12 PM
NoMoreFWD's Avatar
I am not sure what 2 degrees of advance will help. Is it primarily to close the intake valve sooner, bring up the DCR? I forgot to add that I run non-reformulated 93 octane.
By the way, once I get this figured out, I will be ordering from Thunder and will let them know about the help I received from this board. Thanks.
