PRC 220cc 5.3L stage 2.5 heads
anyone using the PRC 220cc 5.3L stage 2.5 heads from TSP? what are some pro's and con's of these heads. what kind of power are you making. what kind of cams are you using with them. they seem a little cheap....you get what you pay for comes in mind. just looking a some different options for h/c package. let me know what you think. thanks for any help.
LS1Tech Premium Sponsor
The stg 2.5 5.3l heads should have tons of results in the dyno section. We typically build them with 2.02 intake valves & a 1.57 exhaust valve. I'm currently working on a 2.055/1.60 valve setup for those cylinder heads that will be available in the next week or so! Look for bigger flow on both intake & exhaust, but at the expense of some p/v.
I'll have some additional information very shortly!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Mine were shipped out Wensday I'm told. I was reccomended the 233/238 cam. I wish I wouldve gone with the MS3. Flycutting isnt a option so I couldnt do MS4. I look foward to them.
