TR224 CAM.....can I use 7.425" Push Rods?
I have had the TR224 CAM and TR 7.4" pushrods installed since last April and the ticking noise is driving me nuts when headers are on the car! It's not an exhaust leak or check valve flutter.........I tried blockoff plates and even swapped on a different brand of Header and it didn't make a difference. I then yanked the heads and popped in some Comp Cam's 850 lifters thinking maybe one of the stockers was on the way out........didn't fix a thang. Finally, putting the stock manifolds back on made it quite down.......but manifolds suck! Question. Would 7.425" pushrods quite down the gremlins tap dancing under my hood without having an adverse affect on performance. Also, was thinking of changing the Comp 918 springs out for a set of Patriot Gold Dual springs........not that that would affect my first problem........I have 13K on the cam/springs and if I have to pull them to check them I'd just as soon replace them. I have broken spring phobia, so I was thinking the Dual Srpings might be a safer bet for a coward like me? Any reason not to put the dual springs on?
Thanks,
Mike
2002 M6
Mods: TR224 112, Comp 918, Dynatech L/Ts & cats, 3.73, SLP CAI, Magnaflow Cat Back, 160 T-Stat, PCMforless tune, NGK-TR55, MSD Wires
Thanks,
Mike
2002 M6
Rocker studs are torqued to spec........that is one of the 1st things I checked. I also checked the O-ring on the oil pump pickup when I put the new lifters and LS2 timing chain in. Rockers appear fine.....no cracks and not missing any needle bearings. I talked to Dave at Thunder Racing and he agrees with what your saying.........stick with the 7.4 p-rods and 918 springs. Good to hear the same advice repeated...........Thanks for your response!
i run dual springs on everything, they are a excellent choice. as far as ticking noise, it is so common in these motors once you put an aftermarket cam shaft in them. 90% of thse cams a ground with very fast seat to seat timing, to get the engine to build as much vaccum as possible at idle.
You could buy the pushrod length checker from thunder for $20 to see what the correct length would be instead of guessing. If pushrod length is your problem it would have saved you a ton of work.
Originally Posted by Grimes
I have heard of people using the 7.425 with success. Don't forget that the base circle of the 224 cam is smaller than stock, so the slightly longer push rod is making up for it.
