Car has to crank for a while to start (lifters not holding pressure)
Is there anything outside of preload that can cause this?
I have to crank for a bit, then it starts to hit and then starts up just fine
running the caddy lifters and 5w30
Please help!
Nick
Please help!
Nick
try turning the key on and waiting for 3 seconds before you "crank" it. if it fires right up there is your problem. does it do the same if you cut it off & recrank it?
btw- i've seen a lot of cars with aftermarket fuel pumps do this, mine included. some worse then others.
Ok, I'll keep an eye on the fuel pressure gauge during lunch, it has the same LPE pump in the tank that it had before I put this new motor in and it didnt have this issue, so thats why I pointed to the lifters first.
thanks again for the help
Well, I cycled the key a few times and that was the problem, but this damn thing has ran for about 45min now and I never had to do the key cycle thing before, anyone have any ideas why it would be bleeding off?
02Z w/LPE pump
Thanks again for all the help
02Z w/LPE pump
Some of the foreign cars have fuel accumulators which hold the fuel preasure constant. I am not sure if Pontiac does if so replace it because it is leaking past the diaphram and not holding preasure.
