LSA question for my cam choice
Old 03-20-2007, 09:46 PM
01redws6ta's Avatar
Default LSA question for my cam choice
Ok, I'm pretty much set on the 228/232 .588/.595 XE-R lobe cam, but I'm not sure on the LSA I want. I'm not sure if I want 10 degrees of OL with the 110 LSA (110+4 would be my choice for DCR reasons and lower RPM power). Would this make it idle really rough and make it very hard to tune? Should I just opt. for the 112 LSA (112+4) to get only 6 degrees of OL? I realize this would drop my DCR down by approx. .14. Would this make much less power than the previous mentioned cam? I'm trying to make the most under 6200 Rpm power/torque with my stock heads...not a daily driver (01 w/20K miles). Any feedback would be appreciated, thanks.
Old 03-20-2007, 09:54 PM
white_camaro's Avatar
im no expert but if you have a good tuner go with the 110+4. it should be a little easier to tune since your an m6. are you keeping your stock heads? just wondering because i learned a little to late that its better to spec your cam to your heads then pick your heads according to your cam. i like my cam but ill be yanking it out to make the most out of some etp 215's.
Old 03-20-2007, 11:00 PM
hammertime's Avatar
Do you plan to swap heads later? If so, you can mill & change gaskets to get the SCR where it needs to be to work with that cam straight up. The problem with advancing it 4 degrees is that it puts your IVC where you want it to keep your DCR high, but it also moves all the other VE's.
Code:
Intake Valve opens - IVO	32.5	8	-31.5	BTDC (- indicates ATDC)
Intake Valve closes - IVC	64.5	40	0.5	ABDC
Exhaust Valve Opens - EVO	74.5	50	10.5	BBDC
Exhaust Valve Closes - EVC	26.5	2	-37.5	ATDC (- indicates BTDC)
Exhaust Centerline - ECL	114	114	114
Overlap 	                59	10	-69	degrees
Your 40* ABDC Intake Valve closing point is right on for you goals with power peak and DCR, but that 50* BBDC Exhaust Valve opening shortens the power stroke and softens your midrange torque. Not only that, your Overlap Bias is +3, which will make power drop quickly after the peak.
Try these:
Code:
Intake Valve opens - IVO	24.5	0	-38.5	BTDC (- indicates ATDC)
Intake Valve closes - IVC	64.5	40	1.5	ABDC
Exhaust Valve Opens - EVO	66.5	42	3	BBDC
Exhaust Valve Closes - EVC	26.5	2	-37	ATDC (- indicates BTDC)
Exhaust Centerline - ECL	110	110	110
Overlap 	                51	2	-75.5	degrees
Same 40* IVC, same DCR. 8 degrees less overlap, eliminating tuning concerns. Plus, your EVO jumps up to 42* BBDC, enhancing mid-range punch, and your Overlap Bias goes to -1 for agood pull past the peak.
Here is the down side - those numbers are for a 220/224 110+0 cam that everyone and their brother will tell you is too small, and that you'll want to go bigger right away. The VE's are pretty close for what you want though, and if nothing else, my post should help spark some interesting discussion.
Good Luck!
Old 03-21-2007, 10:47 AM
BigBake's Avatar
It is funny that you mentioned how common the camshaft profiles seem to be when playing around with the numbers. Getting rid of the advance eliminates a lot of problems, one being tuning, and the rough idle. I am looking at a cam for my 383 which currently has a T-Rex in it, after playing with the number I have come down to this:
Code:
Intake Valve opens - IVO	29.5	5	-34.5	BTDC (- indicates ATDC)
Intake Valve closes - IVC	69.5	45	5.5	ABDC
Exhaust Valve Opens - EVO	71.5	47	7.5	BBDC
Exhaust Valve Closes - EVC	31.5	7	-32.5	ATDC (- indicates BTDC)
Overlap 	               61	12	-67        degrees
I think this will do well with my setup, but when you look at the advertised numbers you think it looks ridiculously small for those cubes.
230/234 .592/.598 110+0
Old 03-21-2007, 11:54 AM
PREDATOR-Z's Avatar
Code:
Not really, I run a 232/234 113+0 on a mostly drag setup 370, why because with the right SCR/DCR it gives me the power I need to propel my heavy beast and responds very well to nitrous with gobs of trq.
A lot of poeple will tell you, 3/4 of the enthusiasts "overcam" their rides. Overall it is a COMBO for specific application one has to look at.
Old 03-21-2007, 03:03 PM
JPH
JPH's Avatar
i have used similar profiles to this cam, and have put them on a 112lsa. power between the 2 would probably be very minimal, with the 110 performing better down low, and 112 rpming a touch higher up top.
Old 03-21-2007, 08:25 PM
01redws6ta's Avatar
I need excel so I can do the DCR calculator tables, I guess. Is this how you guys come up with these numbers? I just saw a table posted in another thread which had the specs. for the cam I'm interested in. Hammertime, what kind of lift did the 220/224 cam you mentioned have?
Looking back through other threads, I found where Patrick G (who seems to be a well respected camshaft expert) said that the cam I mentioned would be the biggest you would want to go with stock heads and he liked it because of the higher DCR (110+4).
I looked for a sound clip of the 228/232 .588/.595 110+4 cam and couldn't find one. Does anyone have one by chance?
Old 03-21-2007, 09:55 PM
hammertime's Avatar
I used XE-R lobes, so int & ex come in at .581 on that one. You could go to LSK lobes, which should still easily clear at these durations, even at .632/.636 lift.
Old 03-22-2007, 01:27 PM
Ragtop 99's Avatar
.14 is not a huge hit on the DCR. However, if the low end is important to you, reduce the overlap by reducing duration to a 224/228 110 108. The lower overlap and later EVO of the 224 cam will make more low end torque than a 228/232 110 106. The 224 will still have good power up top, just a few HP less than the 224 cam.
