Timing Chain and OIL PUMP!!
Old 03-20-2007, 10:52 PM
4yall2nv's Avatar
Default Timing Chain and OIL PUMP!!
I have a 6.0 lq4 motor in my 2000 z28, i was wondering if i need to upgrade the timing chain and the oil pump or will the stock parts be fine? cam is a 236/242 613 612 on a 112 or 114! if i buy the timing chain will i need the whole timing set or just the ls2 timing chain by itself? which ported oil pump do u all recommend? thanks in advance!
Old 03-21-2007, 10:27 AM
4yall2nv's Avatar
anyone? come people i need info!
Old 03-21-2007, 10:52 AM
Z'mnypit's Avatar
Id at least put the LS2 chain on if you already have it apart. You want need the sprockets just the chain. As far as the oil pump goes, I personally like the melling (spelling) ported pump.
Old 03-21-2007, 11:00 AM
4yall2nv's Avatar
thanks, and by gears what do u mean?
patriotformula's Avatar
ITs a good insurance measure for what (like 200 bucks). Your spending all this time and money why not. I bought an SA Gear double roller and it is a pretty cool piece. I think your oil pump might be sufficient though. I put on just a standard ls6 and it works awesome.
Old 03-21-2007, 01:25 PM
Z'mnypit's Avatar
Sorry I meant to say chain.
Old 03-21-2007, 06:15 PM
ArcticZ28's Avatar
At least an LS2 chain. Sprockets would only be imperative if they look worn, but I would probably do it just for peace of mind. If you feel up to it, put in a ported pump with higher pressure spring.
Old 03-21-2007, 06:48 PM
4yall2nv's Avatar
thanks guys, i guess i need somemore parts!
