cam swap trouble
cam swap trouble
did a cam swap and changed the oil pump on a final check to make sure there were no leaks and I see a steady flow of oil coming out from the pan right above the oil filter. I have the pan back down now and I need a little advice or help on what to do. by the way I have good oil pressure. thanks in advance.
You're supposed to put RTV between the gasket and the pan, and the pan to block areas. Especially in the back cause it's a critical area where the rear cover, block and oil pan all meet. it's prone to leak in this area.
My question is.... why did you drop the pan in the first place to change a cam?
Originally Posted by snakesmash'nLS1
like he said i changed the oil pump and had to lower it I am going to put some rvt on it this today thanks guys
