11s on stock heads?
11s on stock heads?
I did some searching, but couldnt come up with anything. Is this possible? Also if you are running 11s on stock heads what is your setup and is it daily driven? I was look at about 400rwhp plus traction to get me there. How streetable are the larger cams making good power? I was looking at either the G5x2 or the Raging230 cam. I know I will need gears with a larger cam like that.
Thanks
Jeremy
Thanks
Jeremy
I can shift faster than you.
Re: 11s on stock heads?
11.80 w/ stock heads and cam
11.25 w/ TR230/stock heads
It has been done many times. Mike Hoffpauir went 10.98 with stock heads and a Futral Motorsports 226 cam in his automatic '00 Z.
my set up is very mild and passes emissions testing. car is full weight and daily driven.
mid 11's. see sig.
some videos are in eastern forum of that run.
cam is 221/221, 558 lift,114 lsa. not nearly as radical as the newer cams being used lately.
new format: does sig get attached automatically?
mid 11's. see sig.
stock heads, comp cams 230/228,591/588 110lsa +4*. this weekend i was running 11.60's@117. raceweight of 3100 lbs and a da of 3800'. i drive my car in track form on the street everyday. 4400 stall, 4.56 gears, skinnies, hoosier qtp's.
mods and times in sig. i made 340 rwhp with mild tune, iwas getting 4 degrees of knck so we didnt continue. cam is pretty small by todays standards. looking at bigger cam and heads soon. that old saying,keeping it mild or steetable doesnt last long fo some of us. heck i remember when i said ill never do alot of stuff. jason
LS1Tech Premium Sponsor
Trevor ran a best of 11.41 @ 116.85 with a 1.53 60' with stock heads and our 228R camshaft in the SS shop car. It was with a 3,526# raceweight, and it was even on BFG DR's.
Brian
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
Texas Speed & Performance
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
