Head Casting Number ?
Old 05-23-2007, 03:08 PM
95GreenZ28's Avatar
Exclamation Head Casting Number ?
I want to have a set of heads ported by a guy here in town. What are the best casting numbers to use as a base for ported heads? Thanks in advance guys
Old 05-23-2007, 03:39 PM
headed-ws6's Avatar
If your talking about stock heads I would say that the 241 casting number is the best way to go if you want a ported set. next step up would be the LS6 243 casting.
Old 05-23-2007, 03:45 PM
JPH
JPH's Avatar
#243/#317 are very good.
Old 05-23-2007, 04:28 PM
MPHmotorsports's Avatar
243's for sure.
I wouldn't even mess with the 241's, 806's,853's etc.
Unless your gonna do a 5.3 head, but I perfer the LS6 243's.
Old 05-23-2007, 06:14 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
go with the 243s
Old 05-23-2007, 07:25 PM
CARTEK Racing
WS6TransAm01's Avatar
its all about the 243's
I have a set of ported 243 heads and am making 508rwhp on a stock ls1 shortblock.
Old 05-23-2007, 10:52 PM
staringback05's Avatar
depends on what you have and what you want....241s if you have them stock, 243s for better flow, 706sfor higher compression....soooo
Old 05-23-2007, 10:54 PM
headed-ws6's Avatar
317's for lower compression they are 72cc chambers
Old 05-23-2007, 10:56 PM
excuse me i meant 706s for higher compression
Old 05-23-2007, 11:52 PM
Tainted's Avatar
i got ARE P&P #241 heads. but they came with my motor from speed inc. anyone know how much power those would be worth comapred to the 243 castings?
heres STOCK head casting #'s and info
853 97-00 aluminum 5.7
241 01-03 aluminum 5.7
243 LS6 aluminum 5.7
852 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron heads
317 01 and up LQ4 6.0 aluminum heads
035 02 and up LQ9 6.0 aluminum heads
Even more info:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559853 (1997-98)
12559853 (1999-00) (not sure why same PN)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
Old 05-23-2007, 11:54 PM
well if their already P&P depending on the job, id say there going to flow as well or more then the ls6 heads....once again depending on the flow job
Old 05-23-2007, 11:56 PM
Tainted's Avatar
well like i said agustino raceing did it. they sued to be really big back when the ls1 first came out then they split. fraser at speed inc said they should be pretty good, but im wondering how good.. I wanna put down 400rwhp+ with my 228R cam and the more the merrier!
to the OP: hope that head info helps ya some!
Old 05-23-2007, 11:58 PM
well if they have been ported and you have a 228 cam, you should be able to make 400 no problem....
i understand who ported them but that still doesnt tell how far of a port job they did
Old 05-24-2007, 12:00 AM
Tainted's Avatar
wish their site had some ifo, but i guess i could call them as well.
the only thing about me putting down 400rwhp+ is im gonig through a 3k stall so im gonna loose a big chunk on a dyno
Old 05-24-2007, 12:02 AM
numbers are numbers man.....dont so much worry about your power as what you can do at the track....you want to take the stall out and be the guy who says hey look i made huge numbers....but my car is slow
or do you want to be the guy who makes 380 and runs 11s?....not to say you still wont be above 400, your not going to lose that much
Old 05-24-2007, 12:10 AM
Tainted's Avatar
well my ultiamte goal is a very high 11 (11.8's) very low 12's (12.0-12.1) consistantly so hopefully i can pull it off. id just like high dyno numbers so i can buy a pretty little plaque to put near the radio jsut for bragging rights
Old 05-24-2007, 12:13 AM
with that cam and stall many people are running 11.9s.....
Old 05-24-2007, 12:17 AM
Tainted's Avatar
sounds good to me. i may upgrade to a fast 90 intake, but i wanan get a pulley first. ill start digging into the suspension before long, that should make me more consistant
Old 05-24-2007, 01:46 AM
id get into the suspension work ahead of the pulley and the intake
Old 05-24-2007, 08:36 AM
95GreenZ28's Avatar
Thanks for the replies guys. I am running the msv4 and I am wanting ported heads. I just wanted to know which stock heads would be the best to start a port job on. I have a local guy here that says he can do excellent things with the 243 castings so I will go with those unless there are some that flow close to those for cheaper
