Where to set the gap with Diamond rings @
Re: Where to set the gap with Diamond rings @
In an above post, Fireball set his at .018/.022 with his h/c motor.
Jason99T/A said he was going to set his at .022/.026 because he's adding a TNT kit on his solid roller 346.
I'm just quoting them, might want to call Diamond.
Matt
Matt
I can shift faster than you.
Always err on the loose side with the rings, especially with nitrous. There is very little to gain with the slightly tighter end gap, but a whole lot to loose if set up too tight.
.020"/.024 would be fine.
Jason
Jason
