replacin ls1 bottom end
i have a 109k mile ls1 block in my 1998 z28 and i was wondering if replacing the whole bottom end with a 6.0 iron block would be possible?
using my 5.3 teas intake and fuel stuff would this even be a good idea?
(i figure it be easy to get some forged pistons while the 6.0 is out to bc i'm a bottle baby)
yeah im pretty sure thats possible but me personally i wouldnt do it i wouldnt want the extra weight up front and im pretty sure if u forged the ls1 bottom end it will hold alot more power then ur going to throw at it, just my 2cents
just rods and pistons, 1000-1500... that is if you stay with the stock crank. also have to add the cost of the shop to bore.(300-600 depending where you go) maybe a new oil pump while your in there 130
just depends how much upgrade you want to do and what power goals you have
I was also throwin around the idea of forging a extra stock LS1 short block. I figure I can find a high mileage short block for about $500. Then get the following:
Callies 6.125" LS1 Comp star rods w/ARP hardware $599
Mahle Fordge 346 LS1 pistons $509
Clevite bearing for complete motor $300 (kinda just guessed on this could be less)
ARP head bolts $140
GM heads/cam gasket kit $150
All parts from Texas Speed comes out to $1698 + shipping for parts w/o the extra short block. Thats using everything else that could transfer from my current motor. Plus the more work you can do yourself the more you'll save.
ARP head bolts $140
