Oil Pressure head scratcher!
Old 06-16-2007, 02:35 PM
F-BodyGuy98's Avatar
Default Oil Pressure head scratcher!
hey guys well ive installed a STS remote mount turbo system on my '98 Z28...ive had no problems with it except for the fact that now that sumemr is here and the car runs ALOT hotter.....when the car is cold between 160 and 200 the oil pressure is good...idle around 40 and up to 60-70 when accelerating. but when it gets to or a little above that 200 mark it ildes around 20 and only goes up to 40 when i accelerate and when im railin' on it. whats the problem?
Old 06-16-2007, 02:38 PM
rons 00z's Avatar
need a thicker oil would be my guess.
Old 06-16-2007, 03:06 PM
Billy177's Avatar
first off what oil is in the motor now? Secondly Definatly go with a colder thermostat with an sts syetem to prevent detonation and see where your pressure is at from there.
Old 06-16-2007, 03:54 PM
well this lst oil change i put in the castrol 10w-30 high mileage cuz it does have like 76000 miles on it.
Old 06-16-2007, 10:37 PM
98 Z28's Avatar
Mine's doing the same thing, It actually goes right under 40 while getting on the gas and when i let off it goes a little above 40. Has about the same amount of miles as your's too. I was told might be the oil sending unit going bad in the post i started.
Old 06-17-2007, 05:02 PM
thank you guys for all the help and if any one else has an idea as to what may be causing this please let me know
Old 06-17-2007, 05:49 PM
oange ss's Avatar
if the turbo uses the same oil supply as your motor you need to step up the oil weight..like 20w50
Old 06-17-2007, 06:31 PM
Mike94ZLT1's Avatar
76k miles is not high mileage for an LS1, theres plenty of guys on here with more than twice that.
Old 06-17-2007, 07:12 PM
could it be because the turbo gets oil to hot?
Old 06-17-2007, 07:28 PM
oange ss's Avatar
yes....
Old 06-18-2007, 12:17 AM
how many of u think that having the lucas oil stuff that prevents oil useage may have helped at all?
Old 06-18-2007, 12:57 AM
Mike94ZLT1's Avatar
Lucas oil additive is the devil!
http://bobistheoilguy.com/images/lucas/lucas.htm
Read all the way through. LS1's have a gear style oil pump BTW.
Old 06-18-2007, 03:25 AM
DaddySS's Avatar
Do not put oil additives in the engine. You only have a few good choices - lower the thermostat to a 180 or 160 and set your fans to to come on at 190, check your actual oil temperature and possibly install a cooler, or increase your oil viscosity, 5w 40 or 10w 40 for hot weather. Use synthetic if you can.
